The board is Asus P7P55D-E Pro.
And there's CF 2 x 5870 in there as well.
1 WD Black.
1 OCZ Vertex 2 SSD.
The V9 black has huge fans and should be relatively quiet with silent 230mm fans installed.
I'm thinking airflow directions here. Contemplating if I should get this case or a conventional front-to-back tunnel, which might go better with the airflow direction of the Mugen. One other example I have in mind is Lian Li Armorsuit PC-P50.
Which option will be colder? Which will be louder?
Thanks
1 WD Black.
1 OCZ Vertex 2 SSD.
Thanks
