APPROXIMATE PURCHASE DATE: ~within the next 4 weeks
BUDGET RANGE: preferably $1000, max $1200 after rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Poker, databases, gaming, movies, music, browsing
PARTS NOT REQUIRED: mouse, keyboard, monitor
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: None
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1080
Other Comments: Looking to keep this computer/upgrade parts when need be for the next 2 years, so I want to create a solid base to build around for the future. In terms of gaming, I don't need anything too hard-core, just so I can occasionally play StarCraft 2, and any other games on medium settings for the next year
added from my 2nd post:
I currently have 2 monitors and will eventually be adding a 3rd. Ultimate goal within the next 6 months-1 yr. is 2 20" monitors and a 30". So yea, multiple display capabilities is a must.
And I will be running some pretty intensive software that need to read from the drive at lightning fast speeds, so a solid SSD is a must as well (although it doesn't necessarily need to have a ton of space, just fast)
Build I am leaning towards so far:
Processor:
Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067&cm_re=i5_760-_-19-115-067-_-Product
Motherboard:
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621&cm_re=p7p55d-_-13-131-621-_-Product
Power Supply:
CORSAIR HX Series CMPSU-750HX 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Produ...39010&cm_re=corsair_hx-_-17-139-010-_-Product
SSD:
Intel X25-M Mainstream SSDSA2M080G2XX 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167027&Tpk=N82E16820167027
RAM:
A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
Video Card:
Case:
Adding up all those components puts a shade over $1k without the video card and case included. That's without combo deals or anything like that, which I have absolutely no idea how to look for on newegg.
Also, I have no preference for Intel over AMD, so if anyone thinks AMD would suit me better, then I'm all ears.
Thanks
OVERCLOCKING: Maybe
Processor:
Motherboard:
Power Supply:
SSD:
RAM:
Video Card:
Case:
Thanks
