Hi guys,
This question is a little specific in nature to CM users. For those using CM extreme power supply, did you notice a small plastic sheet in the power supply, covering half of the unit? Do you guys know what's its function?
I am asking this because the PSU is getting EXTREMELY noise, because its temperature is rather, so I am thinking may be removing the plastic sheet could help to lower the temperature, any idea?
For those who doesnt own a CM, you can see from this picture
http://mmdstore.com/z/index.php?main_page=popup_image&pID=9
There is a plastic sheet covering the upper half of the PSU, and if you view if from the top (facing the fan), you will see that the plastic sheet covers half the fan.
Thanks.
Thanks.
