Solved
Blue screen and memory problem?
Hello, I have blue screen sometimes and memory could not be read problem.
i built my pc recently with
amd athlon II x3 435 rana
ocz 1333 2x2gb ddr3 ram
ati radeon hd 5670
wireless lan card
sata cdr drive
sata hdd drive
asus m4a87td/usb3
psu thermaltake 430w
antec 3000 case
is my psu not enough?
please help me
thank you
18 answers Last reply Best Answer
More about blue screen memory problem
  1. Hello, and welcome to the Forum.
    You PSU is fine. I would think your RAM is off voltage or off timing. Try to enter the BIOS and post specs here.
  2. should i erase them? what to do with them?
  3. i posted pics of my bios
    thank you
  4. I cant get to them!
  5. then, i don't know how to post my pic, can you email me fivlemon@naver.com
    then i'll send you my picture
    or
    what information exactly do you want?
    my dram voltage is set to auto
    i can't find timing
    sorry, i am very noob, but i want to fix this problem
    thank you
  6. How about this:
    What is your motherboard?
  7. asus m4a87td/usb3
    thank you for helping me out
  8. Hmmm...What I saw was issues with memory overclock.
    What is your specific RAM?
  9. it's ocz platinum 4GB (2x2gb)240-pin ddr3 sdram
    ddr3 1333 (pc3 10666) desktop memory model
    ocz3p1333lv4gk
  10. Best answer
    All i can say is horrible RAM. Also from the looks of the specs, it is an i7 RAM set, not an Athlon X3 set. I don't blame you, I blame the RAM. Plus OCZ is well...not so good at the RAM deal...if you know what I mean?
  11. ok i see
    thank you
    then, could you recommend what ram is good for my setup?
  12. http://www.newegg.com/Product/Product.aspx?Item=N82E16820146744
    Mushkin is great and reliable!
    I don't think you will complain. It is US, also.
  13. wow thats amazing $25 for ddr3 2gb wow!...
  14. ^ Sarcasm lately...?
  15. nope. completely serious. why is ddr2 so expensive?
  16. Old tech. Maybe DDR3 is still new and DDR2 is most widely used because of the old Athlon and Pentium 4 computers 99% of the world still uses with Win XP. People...it is called an upgrade...
  17. thank you for recommend!
  18. Best answer selected by fivlemon.
Power Supplies Blue Screen Memory Components Product
