Tom's Hardware > Forum > Digital Camera > Digital Camera General > Little noise inside my Minolta Z10...
Forum Digital Camera : Digital Camera General - Little noise inside my Minolta Z10...
Archived from groups: rec.photo.digital (More info?)
Hello !
When I shake my new Minolta Z10 from back to front and front to back, I ear
a little noise inside, just like a piece of plastic travelling inside (it
seems to be near the viewfinder, but it's dificult to locate...)
I borrough about that...
Is it normal ?
If somebody has the same camera, can he tell me ?
Without this noise, I think the Z10 is a very good digital camera for a low
price !
Thanks for your answer.
Regards,
Alf92
Sponsored Links
"Alf92" <alf92[NO-SPAM]@freesurf.fr> wrote in message
news:41d7e61c$0$20274$636a15ce@news.free.fr...
> Hello !
ear
What is the meaning of the word "borrough"?
Gerrit
Reply to Anonymous
bothered? maybe ;)
Reply to Zog
zog a dit ça :
> bothered? maybe ;)
sorry for my not very good english speaking...
yes I wanted to say "bothered"....
any answer to my question about the little noise ? :)
thanks.
regards,
Alf92
Reply to Anonymous
Alf92 wrote:
> zog a dit ça :
>> bothered? maybe ;)
> thanks.
Been answered in another group or two.
Some cameras sense orientation and the machine makes a noise as it
switches. Mentioned in at least one manual I have seen. I hope yours is
one of them.
Frank ess
Reply to Anonymous
Frank ess a dit ça :
> Alf92 wrote:
>> zog a dit ça :
>>> bothered? maybe ;)
>> thanks.
> is one of them.
No, the Minolta Z10 dosen't have an orientation sensor. :(
the noise sounds "cloc"...
Cordialement,
Alf92
Reply to Anonymous
> Hello !
> ear a little noise inside, just like a piece of plastic travelling inside
> (it seems to be near the viewfinder, but it's dificult to locate...)
> Is it normal ?
> low price !
> Regards,
> Alf92
I don't have a Z10, but I very briefly owned a Minolta Z1 which made a
considerable clunking noise as a result of the lens barrel being rather
loose. You could hear the clunking even when the camera was still inside the
box, when the box was moved. Does it sound like it might be that? That was
more when the camera was moved side to side though, not front to back.
Others mentioned the same thing about the Z1 so I guess it was a fairly
common thing, at least with the early models. This evidently is normal for
some cameras, e.g. at least some Olympus models have a quite loose lens
barrel which reportedly is deliberately designed that way.
N.
Reply to Anonymous
Nostrobino a dit ça :
>> Hello !
>> back, I ear a little noise inside, just like a piece of plastic
>> travelling inside (it seems to be near the viewfinder, but it's
>> dificult to locate...) I borrough about that...
>> Is it normal ?
>> for a low price !
>> Regards,
>> Alf92
> rather loose. You could hear the clunking even when the camera was
> still inside the box, when the box was moved. Does it sound like it
> might be that? That was more when the camera was moved side to side
> fairly common thing, at least with the early models. This evidently
> is normal for some cameras, e.g. at least some Olympus models have a
> quite loose lens barrel which reportedly is deliberately designed
> that way.
> N.
Thanks for all.
Regards,
Alf92
Reply to Anonymous
>> Hello !
>> Is it normal ?
>> for a low price !
>> Regards,
>> Alf92
> that way.
> N.
I went to the shop and I compare with other Z10 : same strange noise !
It is normal.
Thanks.
Regards,
Alf92 http://frpn.free.fr
Reply to Anonymous
> Alf92 wrote:
>> zog a dit ça :
>>> bothered? maybe ;)
>> thanks.
> is one of them.
It is normal.
Thanks.
Regards,
Reply to Anonymous
There are 588 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
