Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > I need help with my wireless connection It disconnects every 5 minutes or so How
Forum CPU & Components : CPUs I need help with my wireless connection It disconnects every 5 minutes or so How
Hello,
i have a belkin router not sure the "version" or anything aand an acer aspire 5532 laptop...it seems my internet will disconnect every 3-5-10 mins i just dont know what to do...but its bothering me... ive reset my router..that didnt help..it gets annoying please help anyone
Reply to ouwarrior3
Hi ouwarrior3, Welcome to THW.
It would help greatly to know the model number of your router, it will be printed on the label.
First, do you know how to get into the router setup? If you can check what the signal strength is set to, it should be adjustable.
------------------------------ Must Read: PSU Info - PC Tools - Guides
Folding@Home: THGC Needs You! -Team 40051
Free Half-Life 2 DM for ATI owners
Reply to thechief73
Your neighbours are stealing your Wi-fi imo
Moto
------------------------------ Once you start watercooling, you are almost automatically inducted into the modding circles as well, because theres rarely a 'from the box, fits everyone' solution, its your ingenuity and resourcefulness that makes it all happen,
Reply to motopsychojdn
In that case, well your in your setup, put a good password on your router. :)
But.. stolen wifi causing disconnects? IDK much about wifi but can that be the cause?
Reply to thechief73
If the stealers (is that even a word? Tis now, bagsied it) bandwidth usage suddenly jumps, it could theoretically shunt the other people connected to it yes
I leave my mobile connected to my network whilst at home, but if I and my Gf both log into WoW, it disconnects the phone lol
Moto
Message quoted 1 times
Message edited by motopsychojdn on 11-29-2010 at 09:00:38 AM
Moto
Yes,I can see that especially if the OP is using an old Router especially with wireless B rather than G or the newer N type
or if it's not set up right (lacking passwords,encrypted etc.).
Myself I have a neighbor with a open router that I could use.I did use his router before for streaming Hulu videos for a while.Always encrypt your router's signals,use passwords,read the manual etc.If the router is of an older vulnerable type just ditch it and get a new one.
Reply to jj463rd
It's a Belkin, pre-programmed to disconnect at random intervals. Worst routers I have ever come across.
------------------------------ HP Pavilion DV7-3020EA Entertainment Notebook PC + Win 7 Pro SP1 x64
GA-870A-UD3 + AMD PH-II X6 1100T BE + Hyper212+ + 8GB DDR3-1600 + GTX460 + Win 7 Pro SP1 x64
GA-870A-UD3 + AMD PH-II X4 840 + 4GB DDR3-1333 + ATI 3450 + SVR08 R2 SP1 x64
Reply to das_stig
Yeah i know how to get into it 4 bars of signal strength... but the thing is the internet pauses and the network bars will still stay the same..... and then reconnects like in 20 seconds... any ideas or settings i can change to cure this problem?
Reply to ouwarrior3
Also my wireless internet is secured.... with a password and everything... ive reset my router...modem...everything..could anyone help meee!!
Reply to ouwarrior3
Pretty much agree with you here.I had one and it proved pretty useless because it wasn't reliable.
My advise would be to get a different brand (look at reviews) and either throw it (the Belkin) away,give it to goodwill or the salvation army or resell it to a sucker.
Reply to jj463rd
There are 1516 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 2 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
