I have an XFX GeForce 7900 GS 450M that has a bad fan bearing (or two) as it doesn't spin most of the time anymore. This causes the card to overheat after only a few minutes of anything but Windows only use and my computer locks up completely when I run any game, causing me to do a cold reboot. I'm currently using my old GeForce FX 5900 XT just to run Windows and play some older and non-graphics-intensive games.
I spoke to XFX Customer Support and found out that even though they offered a Lifetime Warranty with the card, I somehow missed the fact that I needed to register the card within 30 days of purchase to qualify for this warranty. They also do not sell replacement fans and I was told to search eBay for a replacement, but this is not as straightforward as I had been hoping for.
I've removed the fan/heatsink enclosure shroud and the plastic housing that also holds the fan and found that the fan is an Evercool EC5015H12B-B model, which is 55mm wide by 10mm high and is rated at 13.74 max CFM at 5000 RPM. The only site that I've found listing this particular fan is Evercool's and there is no information on what the price would be. Their site links to two different US resellers, but I can't find any evidence that they sell this fan either.
So here (finally!) is my question: what's a decent, cheap replacement either for just the fan (which I can install into the existing enclosure) or a full fan and heatsink that will work on my card? I don't want to spend a lot since I plan on replacing the card with a PCIe card in the near future, but I can't lay down the upgrade price right now. The current enclosure sends the heat into the case, but I'm not opposed at all to a cooler that will send the heat out of the case via an expansion slot, I just want to know what will work best and not cost much at all.
Thanks in advance!
Thanks in advance!
