I would personally go with one of these for the same price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021&cm_re=antec_power_supply-_-17-371-021-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207007&cm_re=xfx_650w-_-17-207-007-_-Product
these units would need to use adapters (only two power connections with the unit) but will still work
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095&cm_re=seasonic_620w-_-17-151-095-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005&cm_re=corsair_power_supply-_-17-139-005-_-Product
I would personally go with the XFX unless you don't like the green.
here is a review of the Kingwin 1000w PSU, I would expect a similar performance from the 700w (both are made by Superflower). I found a review of the older Kingwin 700w and they stated solid power but inefficient past a certain point. Looks like the new versions fixed some of those issues. In short, yes the Kingwin will work. If it was my choice, I would still go with the XFX or Antec from above.
Summary
Kingwin's first attempt at an 80 Plus Gold unit is a pretty good effort. However, it seems that Kingwin has once again gone and let a few performance related items slip and slide in order to get those wonderful Gold numbers. As it stands now, this unit is an improvement on the previous generation Lazer model. I just wish that improvement had been more substantial. Another good, but not great, unit from Kingwin.
The Good:
* more efficient than the last Lazer
* gobs of 12V power
* managed full power at 6 degrees over rated operating temperature
* good voltage regulation
* quiet
The Bad:
* minor rails a little rippletastic... again...
The Mediocre:
* gets a little warm for an 80 Plus Gold unit
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=191
