Try
Vimx Partition Recovery, which specializes in restoring data from deleted partition.
After completely restoring your crucial files, you need to create a new logical partition to replace it for later use as shown:
Right click “Computer Management” to select “Manage”=> Choose “Disk Management” => Right click the deleted partition and hit “New Logical Drive” on the list => format it.
Notes and tips:
1. Stop writing new files on this drive in case of overwriting the original files. The overwriting thing can cause data loss permanently.
2. Save your recovered files on a different storage device in case of recovery failure.
3. Do not forget to create a new partition.
4. Back up your data in a safe place in the future.
