Solved
Weird problems with my PC and Crysis
I am having this weird problem with my PC.
My Specs: i5 750 @ 2.67 with 8gb of ddr3, p55 ftw motherboard, gtx 260 GPU, and 850W PSU Running Windows 7 64 bit.
Problem: I run the crysis demo, its starts working and in my screen appears the message: This demo is intended for ... purposes and then BAM by computer restarts.
I then run the crysis benchmark tool, in 1920x1080 res no AA and everything on high and I get this result:
29/11/2010 23:46:36 - Vista 64
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX10 1920x1080, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 58.00s, Average FPS: 34.48
Min FPS: 26.19 at frame 1953, Max FPS: 42.09 at frame 993
Average Tri/Sec: -29961330, Tri/Frame: -868838
Recorded/Played Tris ratio: -1.06
!TimeDemo Run 1 Finished.
Play Time: 55.27s, Average FPS: 36.19
Min FPS: 26.19 at frame 1953, Max FPS: 43.34 at frame 1008
Average Tri/Sec: -30974784, Tri/Frame: -855977
Recorded/Played Tris ratio: -1.07
!TimeDemo Run 2 Finished.
Play Time: 55.27s, Average FPS: 36.18
Average Tri/Sec: -30956124, Tri/Frame: -855499
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX10 1920x1080 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 3618,5
My temps were: Max GPU : 73ºC Max CPU 41ºC
Then something even stranger happens, under global settings ( still in the crysis benchmark tool) I check the 64 bit box, and then run the benchmark. The game starts loading but instead of doing the benchmark the demo runs and I start playing with absolutely no problems just a bit of lag with the autosave.
Can somebody tell me what the problem could be ?
Thank you
3 answers Last reply Best Answer
More about weird problems crysis
  1. Oh yeah BTW, I when replying you can avoid advanced computer terminology I would really appreciate it. Yeah Im kind of a noob in this :P
  2. Best answer
    maybe a compatability problem between 32 bit crysis and your 64 bit windows 7. Just leave the 64 bit button ticked if it works like that.
  3. Best answer selected by Abanziger.
Crysis Components
