M madhusudhanan Honorable Dec 16, 2012 1 0 10,510 Dec 17, 2012 #1 i installed Windows7. it won't be booting from Hard disk after the completion of OS... and i can't able to format my drives... can you give me some tips...
nukemaster Titan Nov 23, 2004 19,626 6 74,965 Dec 17, 2012 #2 If you had been messing with the partitions and removed the "system reserved" partition. You would leave windows unable to boot. The windows cd has a Startup repair option that should be able to fix this for you. Worth a shot. Upvote 0 Downvote
