Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > First computer build, oddly high i5-760 temperatures help!
Forum CPU & Components : CPUs First computer build, oddly high i5-760 temperatures help!
I just finished putting together my first computer last night. Never done it before, and when I started up for the first time and went into bios the bios is showing my CPU temperatures starting at 45 degrees and climbing up to about 50 degrees. This is in bios!
I am worried that these temperatures are not acceptable as when the processor is in BIOS it should be idling right? I have not done any overclocking yet!
System specs:
Case - Coolermaster storm sniper (All stock fans)
Motherboard - Asus p7p55d-e pro
CPU - Intel core i5-760 (Stock cooler)
Memory - 4gb 1600mhz
Graphics card - evga gtx 470 SC
PSU - 750w corsair
hard drive - 64gb SSD crucial
Any help would be appreciated.
I already took the stock heat sink off and I tried putting thermal past on again after cleaning, maybe i'm doing that wrong?
The air inside the case feels very very cold with all the case fans running?
Reply to rakevinwr
I have all the fans hooked to the cases "dial up fan speed" and i have the knob cranked to 100% the only fan not on that mode is the stock coolers fan.
Reply to rakevinwr
Ambient Temperature?
And what do u mean by cool?
Where I live, I consider 20C cold, and 30++c cool.......
Try using HWmonitor from CPUID, it's free
------------------------------ True Malaysia
Malaysian Fact
LittleGreg:Core i5-2500,8GB ddr3,MSI P67A-C45,Sapphire HD6950 1GB,3TB Total HDD,Xigmatek NRP-PC602
Lappy: Athlonx2QL62, 4GB ddr2, HD 3200 IGP
Reply to greghome
Ambient temp 25
In the case 27
I'll have to give that a try when I get home, but this is very abnormal?
Reply to rakevinwr
50C idle? a bit....check load, it's the most important.
as long as it doesn't pass the magic 70c Mark, u should be safe
Malaysian Fact
Reply to greghome
I just ordered a 212 plus also I want to get it idling around 30 and does prime95 display CPU temp?
Reply to rakevinwr
TBH, I don't really have experiences with that software, but if it doesn't just use HWmonitor to monitor the temperature, and also re-check ur stock heatsink.
Feels odd since my ancient pentium 4 at 3ghz barely touches 50C at idle here in the tropics with ambient around 34C in the day
Malaysian Fact
Reply to greghome
I'm wondering if this I'd caused by a hardware defect and if I should RMA the item back to newegg?
I dont know how Long you have before you can't anymore with them
The system boots fine so maybe that's unlikely?
Reply to rakevinwr
Temperatures at load?
Like I said before, check it with Prime 95 or some CPU heavy games, If it doesn't surpass 70Celcius, it's safe.
Malaysian Fact
Reply to greghome
Well I installed 64 bit windows reset my bios settings and it switched everything to "auto" and power step on all that now my CPU Is idling as low as 33 and occasionally hitting 60 under load.
I also switched storage configuration to ahci cause I was told this was faster for ssd? Except in 32 bit my windows experience was at a 7.8 now it's at 7.4 for hard drive?
I noticed using asus's probe that my vcore goes up and down almost directly related to temperature so is there any negative reason not do this since I won't over clock until I get my after market cooler anyway?
Another thing: the memory is only operating at 1333 even though it's 1600 now. Thanks for all the help!
Reply to rakevinwr
Temperatures are ok like that, 33C idle,60c load
I don;t own a SSD, so don't ask me
Also, Windows Experience is nothing, I can get a score of 1 if I coupled an old Pentium 4 no HT with a GTX580 :lol:
About ur RAM, are they installed in both channels?
Message quoted 1 times
Message edited by greghome on 12-01-2010 at 04:33:01 PM
Malaysian Fact
Reply to greghome
Sorry for sounding like such a noob but what do you mean in both channels?
Reply to rakevinwr
The LGA1156 mobo should have dual channel memory, 4 slots.
IF you inserted it like this, it's running one channel
http://www.legendmemory.com/files/article_images/embedded/317.2.jpg
If you inserted it like this, it's running dual channel
http://www.msi.com/uploads/Image/techexpress/mainboard/2channel/2ch-2.jpg
Malaysian Fact
Reply to greghome
There are 1564 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 2 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
