Are these parts compatible?
I'm building a PC for casual gaming with a tight budget. I found these parts, and I was just wondering if they are compatible with each other.. as I am new to this stuff. ;D
I already have a 7200 rpm hardrive, so I don't need a new one.
Also.. for the power supply, can you tell me if it's enough; Watt-wise.
Motherboard: http://www.newegg.ca/Product/Product.aspx?Item=N82E1681313140
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103704
RAM: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231277
PSU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341022
Video Card: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=5296653&csid=ITD&body=MAIN#detailspecs
IF LINKS AREN'T WORKING, RIGHT CLICK 'OPEN IN NEW TAB/WINDOW', sometimes that works.
I'm open to suggestions, so if there are better products you would recommend, let me know.
Thanks~!
EDIT:
I hope this helps..
APPROXIMATE PURCHASE DATE: Soon.. I'm not sure.
BUDGET RANGE: $500ish
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Adobe, Videos, Internet.
PARTS NOT REQUIRED: Hardrive, Mouse, Keyboard, Moniter, Case
PREFERRED WEBSITE(S) FOR PARTS: Newegg.ca, Tigerdirect.ca
COUNTRY OF ORIGIN: Canada
PARTS PREFERENCES: Don't mind, as long as it's a good quality.
OVERCLOCKING: No
SLI OR CROSSFIRE: No
ADDITIONAL COMMENTS: I'd like it to be able to play FFXIV.
5 answers Last reply
More about parts compatible
  1. Ouch a GT220? I would rather hit a 700 or 800 series IGP chipset rather than fork out for a GT220 @@
    Cut down to a 770 chipset and hit a nice HD 4850 like this one
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102834&cm_re=HD_4850-_-14-102-834-_-Product
  2. ^ +1
  3. Don't know the links {CPU, RAM & PSU} are broke... I'd just list them within the post.
    I'm sorry, I don't know what's wrong with the site. :/
    Sometimes it works, sometimes it doesn't.
    Ahh, thanks.
    Clearly I need to do my research ><
New Build Compatibility Systems
