Hey guys, my computer is slightly screwed. It keeps crashing after about 10 - 20 seconds of booting, and when i try to reboot it, it gives me an error in BIOS beeps. It's 4 beeps - I've looked it up and this is what it says about 4 beeps...
"You are getting 4 beeps indicating a timer not operational:
* Check for foreign objects such as screws that may ground the motherboard and make sure that screws that hold the motherboard are not too tight.
* Swap the motherboard. "
I've taken apart my computer so there is no problem with loose screws, or screws that are too tight...
Also, now i get an error saying the cmos battery is low... Do you think the 2 are related?
Any help is greatly appreciated, thanks in advance everyone
