Seeking advice on Build with best buy parts
Purchase Date: Before sep 22
Orgin: USA
Budget: 800-900 dollars
Parts From: Best Buy
Use: Gaming (Mainly FF14)
Parts Not required: Video card, PSU
After going through the prebuilt forums, I decided to build my first computer. I have to use best buy because I have a credit card there and have no real funds to get parts.
I have a GTS 250 1gb Video Card and a XION Gaming Series 1000 watt PSU, so those are taken care of.
I read through some of the budget build articles, are those safe to follow?
CASE: Antec - Three Hundred Computer Case
MOTHERBOARD: Asus - Crosshair III Formula AMD ATX Motherboard 1066/1333/1600MH
CPU: AMD - Black Edition Deneb Phenom™ II X4 Processor 965
RAM: Kingston Technology - HyperX 2-Pack 4GB PC3-14400 DDR3 DIMM Desktop Memory
HARD DRIVE:Western Digital - Caviar Black 1TB Internal Serial ATA Hard Drive for Desktops
CD/DVD DRIVE: Any?
MONITOR:
14 answers Last reply
More about seeking advice build parts
  1. Well, I suppose if you mean here on tom's then you could prolly trust those.
    I just noticed on the newsstand the other day that PCWorld magazine has a special edition out right now that would be perfect for a newbie to get started on a build. PC world is a publication I trust.
    Of course you have the community here at Tom's that will be happy to help if you get stuck.
    Does this mean you also need the keyboard mouse, etc?
    In that price range, it may be a good idea to consider an AMD build. Ultimately it may depend on how flexible your budget is.
    Here's a start:
    AMD X4 955 BE $155
    AMD 890GX motherboard $125
    4 gb ddr3 1333 or 1600 ram: $100
    Antec 900 or 902 or Coolermaster case: ~$100
    Samsung f3 1TB hard drive
    Any old DVD-Rw will do, try to find one that's not too loud
    Monitors:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236052 this one is highly rated
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824009255 has LED backlight
    This one is my current favorite:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236075
    Here's a start:
    AMD X4 955 BE $155
    Monitors:
    I have to use BestBuy parts only and I think they don't carry the samsung f3.
  3. updated my list.
  4. Is there a reason that you have to use best buy? If so, you are getting a lot less hardware for your money...
    If you can shop other places, it will greatly improve what you can get.
    I have no cash for the build but I have a bestbuy credit card so its my only option.
  6. Credit card or gift card? Credit sucks for purchasing computers.
  7. I have a build for you that might work out for $789.92.
    Its not as good as a system you'd put together from, say, newegg, but It's more solid than any of their direct builds for the same price:
    Asus AMD 770 motherboard: $99.99
    http://www.bestbuy.com/site/Asus+-+AMD+ATX+Motherboard+1066/1333/1600/1800MHz+(Socket+AM3)/9877538.p?skuId=9877538&productCategoryId=abcat0507008&id=1218187478917
    AMD Athlon II X4 630: $109.99
    http://www.bestbuy.com/site/AMD+-+Athlon%26%23153%3B+II+X4+Quad-Core+Processor+630/9877529.p?skuId=9877529&productCategoryId=abcat0507010&id=1218187477733
    4 GB DDR3-1300 (DDR10666) RAM, Corsair: $89.99
    http://www.bestbuy.com/site/Corsair+-+2-Pack+2GB+PC3-10666+DDR3+DIMM+Memory+Kit/9590677.p?skuId=9590677&productCategoryId=abcat0506001&id=1218128733297
    Seagate Barracuda 1 TB Hard drive: $79.99
    http://www.bestbuy.com/site/Seagate+-+1TB+Internal+Hard+Drive/8490625.p?skuId=8490625&productCategoryId=abcat0504002&id=1186003683968
    HP DVD Burner: $39.99 (this was the cheapest they had!)
    http://www.bestbuy.com/site/HP+-+24x+Internal+Double-Layer+DVD%26%23177%3BRW/CD-RW+Drive/9402247.p?skuId=9402247&productCategoryId=abcat0504007&id=1218099651274
    EVGA Geforce GTX 460, 768MB $204.99
    http://www.bestbuy.com/site/EVGA+-+GeForce+GTX+460+768MB+GDDR5+PCI+Express+Graphics+Card/1177792.p?skuId=1177792&productCategoryId=pcmcat182300050008&id=1218230516560
    Antec 300 Case: $69.99
    http://www.bestbuy.com/site/Antec+-+Three+Hundred+Computer+Case/9254656.p?skuId=9254656&productCategoryId=abcat0507006&id=1218069452235
    Antec Earthwatts 500W: $89.99
    http://www.bestbuy.com/site/Antec+-+EarthWatts+500-Watt+ATX+CPU+Power+Supply/8545158.p?skuId=8545158&productCategoryId=abcat0507009&id=1188560188623
    Additional 120mm fans are $14.99 apiece
    This isn't as good as you could parts together at another site, but its a solid build
  8. You can do what you want, but as stated, now you're paying interest on your purchase, as well as having the parts overpriced at Best Buy...
    If it were me, I would save up and buy something when I actually had the resources, instead of buying overpriced parts that I will have to pay interest on top.
    If you don't have an immediate need, I would hold off...just my opinion. If you do happen to go ahead, best of luck and enjoy it.
  9. If you're using a credit card, you can also get the parts online at Newegg...
  10. The only reason I ever buy from Best Buy is when I want to go run to the store and buy something because I am too impatient to wait for an order from Newegg, Tiger Direct, or Directron. Best Buy doesn't sell motherboards in there retail stores, so I am assuming you are planning on buying your parts online. If thats the case, I would definitely shop around for your parts.
    he has a 1000 watt psu already and a gpu (a gts 250)
  12. may i ask why did you get a 1000watt psu? it is such overkill for your system its actually scary, as you cant get a second gts 250 and put it into SLI as you are going for an amd build, what i would do is go for an intel build like an i5 760 or something and get a 2nd gts 250 and SLI them
  13. or i would sell the gts 250 and get a gtx 460 or something
  14. Both were given to me for free. After reading some reviews on XION I think I might pass it up and get a more quality brand like corsair 750watt
Homebuilt Build Systems Product
