Hi all, new here and could use some feedback.
My wife went downstairs this morning and smelled a strongish "warm plastic smell" (not burning; sure you guys know what I'm talking about) from my system. I've never had it before, though I know the smell from past systems, am slightly smelling it now and it's not a good smell to be having.
It seems be to exhausting (where I smell it most) out the rear fan, and not the PSU, though the PSU is right above the rear fan, so who knows.
Problem is, temps are completely normal, and I see no visible damage/burnt capacitors etc. on my mobo.
Since I've never had it with this system before, can someone please let me know if I should be concerned? What else could emit this smell out of nowhere?
It's not massively strong, but enough to be noticed, and never had it on this system before.
*Note: I do serious work from home, and really could use feedback about whether or not I could have a potential problem and with what.
Specs:
Gigabyte UD5 X-58
i7 950 (stock)
6GB Corsair Dominator
GTX 480
Corsair 850HX
WD Raptor and a Seagate HDD for storage.
Temps (HWMonitor; perfectly normal/usual):
TMPIN0 34C (northbridge, I think)
TMPIN1 31C (southbridge, I think)
TMPIN2 41C (ambient, I think) ...these three could be mixed-up, but either way, temps are fine.
CPU - all cores between 37C-45C
GPU - 44C-48C
HDDs - 33C and 31C, respectively.
PSU is as cool as can be... not even warm air from exhaust.
Not new to building or troubleshooting systems, but I'm stumped, as I've no symptoms of a problem and no visible cues. I'm concerned because I do serious work from home and cant afford for something to die on me.
Believe I've had this in the past on other systems and it just faded as quick as it came. Right now, it's pretty noticeable.
Thanks in advance for any feedback/ideas.
Specs:
Gigabyte UD5 X-58
i7 950 (stock)
GTX 480
Corsair 850HX
GPU - 44C-48C
