500W Corsair power supply enough for an Athlon x3 and a GTX 460? -OC'd
Last response: in Components
December 1, 2010 11:39:01 AM
Hi,
I'm just about to order all the parts, but just before i do, i'd just like to confirm that a corsair 500w PSU would be enough to run;
-3 Sata Hard drives
-Athlon II X3 445 3.1 GHz Overclocked to as far as i can get it with this an Arctic Cooling Freezer 7 Pro rev 2, so say 3.7GHz.
-GTX 460 also overclocked as far as i can, so say around 850 core.
-A couple of fans.
So if you could just confirm that it all wouldn't explode when i turn it on i would be very gratefull,
Thanks,
Joe.
a c 91 ) Power supply
December 1, 2010 12:07:16 PM
Yes surely.. Although, if you are asking with reference to the CX 500, I'll recommend you to opt for the VX 550..
December 1, 2010 12:12:41 PM
Thanks, and out of interest, why would you opt for the 550?
December 1, 2010 1:15:07 PM
The VX series is a Tier above the CX series in terms of quality and poweR output.. Also, the price difference is not that significant.. So unless you are on a strinGent budget scenario, it is recommended to opt for the VX 550.. You can also look at the Seasonic S12II 520 as a viable alternative..
