Building my own please help|!!
Last response: in Components
hi trying to build my 1st comp. does any1 know if this all works together? many thanks richard
Antec 902 Nine Hundred Two Black ATX Case - No PSU
AMD Phenom II X6 Black Edition 1090T 3.2GHz 9MB Cache 125W Retail Box Processor
Asus CROSSHAIR IV FORMULA 890FX Socket AM3 8 Channel Audio ATX Motherboard
Corsair CWCH50-1 Cooling Hydro Series H50 High-performance CPU Cooler supports LGA1156 LGA775 LGA1366 AM2 and AM3 processors
Antec TruePower New 650W Modular PSU - 80plus Bronze and SLI Certified 3x SATA
Gigabyte GTX 460 OC 1GB GDDR5 OC Edition Dual DVI HDMI PCI-E Graphics Card
Corsair 4GB DDR3 1333MHz Non-ECC (9-9-9-24) 1.50V - Core I7, Core I5 And Core 2/AMD Phenom Ii - Dual Channel
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cach
windows 7 ultimate
More about : building
Get a cheaper mobo, unless you're planning on buying quad/tri SLI/Xfire cards. If you just want to do 2x SLI/Xfire you can better get a waaaay cheaper mobo, it'll save you money for:
Better PSU(it's a good PSU, but the wattage is too low for 2 6870's if you want to upgrade soon)
2 HD 6850's of 2 GTX 460's(the Gygabytes are good, 6850 and 460 both have the cool coolers which will keep it @ 45C in a regular game, had a single one)
Do you really need a six-core? It won't give you more performance in games then a X4 955, unless you're playing a quad-optimized game and running a browser, mailclient, download, and installer @ the same time, you can do all those things with the X4 too when you keep a single GPU, which won't stress the CPU that much. I suggest:
Antec 902 Nine Hundred Two Black ATX Case - No PSU(your own favourite, cant advice you on this one)
AMD Phenom II X4 955 BE
Asus M4N98TD EVO SLI nForce 980A
Scythe Mugen 2 Rev. B
Antec TruePower 650W(same)
2x Gigabyte GTX 460 OC 1GB with the "cool" cooler
Corsair XMS3 4GB DDR3 1333MHz Non-ECC (9-9-9-24) 1.50V
windows 7 home premium
I guess this is your cheapest setup, prices are based on EU/holland, but I'm sure there isn't too much difference in the US
hi yes im using it for gaming, internet. no graphic designing etc. but i want quite a good one so i could update in future. any help would be great! ive taken my last days holiday this week and just sat on the net looking at parts. "theres so many" and too full days to get that list. i just fancy building one then buying one of the shelf. does this seem a good setup? thanks again
to br4m
AMD Phenom 955 Bundle Including Phenom X4 955 AM3 Processor,
Asus M4A88T-M USB3 Motherboard and
PATRIOT 4GB DDR3 1333 Memory
hi thanks for replyi live in england can get this bundle for £267
to br4m
Ask the community
