Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Any advice on an aftermarket cpu cooler?
Forum Systems : New Build Any advice on an aftermarket cpu cooler?
:hello:
1. ASUS P7P55D-E PRO Motherboard.
2. INTEL i5 760 Quad Core Processor.
3. EVGA gtx 470 (Fermi) Superclocked Video Card.
4. SAMSUNG 1TB SATA HD 7200\32MB.
5. SAMSUNG SH-B123A Blu-Ray Combo Drive.
6. CORSAIR XMS3 4GB 1333 Mhz.
7. WINDOWS 7 ULTIMATE 64-Bit OS.
8. CORSAIR HX850W PSU.
9. COOLER-MASTER STORM Sniper Gaming Case.
*. Samsung HD 25" Class Widescreen Touch of Color LCD Monitor with TV Tuner. :sol:
Reply to wiredwrong2012
Best performance/ Value options -
CM Hyper 212+
Scythe Mugen 2 Rev.B
Other high-end options - Noctua D14/ Zalman ZALMAN CNPS10X Extreme/ Prolimatech Megahalems Rev.B with Scythe Slipstream fans or other high-performance fans...
Reply to gkay09
You can use this chart to compare the performance of cpu coolers:
http://www.frostytech.com/articlev [...] 535&page=5
I particularly like the value of the Cooler Master Hyper 212+ at ~$30.
http://www.amazon.com/gp/product/B [...] W88F856JBB
If you don't want to spend that much, you can get the Hyper TX3 for ~$20. It still should be an improvement over the stock HSF. (Free super saver shipping if you spend $25)
http://www.amazon.com/Cooler-Maste [...] 717&sr=1-1
A step up would be the Zaward Vapor 120 for ~$45. It's extremely efficient for its size (no other cooler this size can compete), uses a unique and well designed golf-ball style fan, and includes clips for attaching a second fan.
http://www.tigerdirect.com/applica [...] kwCjCECjCE
http://www.amazon.com/ZAWARD-Vapor [...] B003HC8H0S
------------------------------ http://valid.canardpc.com/cache/banner/1370780.png
Reply to wielander
gkay09's suggestions are very good.
Here's a couple of other good ones that cost a little more.
http://www.newegg.com/Product/Prod [...] -029-04%23
real tests results on a i7 920 which runs hotter then your cpu
http://www.legitreviews.com/article/1389/6/
Message edited by davcon on 09-09-2010 at 06:07:14 PM
Reply to davcon
Think i'll go with the Cooler Master Hyper 212+ @ $30
cooler must not exceed 7 inches in height.
and the Cooler Master V8 I really like but its $100. :fou:
Thank you.
Thank you.
Good choice you won't be disappointed!
No loss the V8 is an average cooler anyways and worth about $50 tops.
Reply to davcon
+1 The V8 is just an average cooler...
CM Hyper 212+ is far better in terms of value/ performance...
Reply to gkay09
There are 1619 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 3 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
