I'm not sure if this is the right forum but I assume it is since water cooling is a mod..
So the relevant parts for my build to water cooling.. I have a HAF 922 with SLI GTX 260's, an Asus p7p55d pro, 3 hard disks, and a cd drive. I would like to install a water cooling system on my graphics cards because I live in a dormitory and the high GPU temperatures can raise room temperatures pretty significantly after even an hour of gaming.
This is my question.. Do you think I need to get a bigger case for water cooling? I've tried to do wire management with my Corsair tx950w porwer supply, but most of the cables are not quite long enough to be wrapped around the case, so I'm having a hard time figuring out if I'd have room to implement the water/liquid cooling system. If I were to implement a liquid cooling system I'd like to look into removing all air cooling also to make the case silent...
any feedback would be amazing! thank you greatly in advance, joe.
Edit: As an aside, I am open to recommendations for better cases for water cooling.
