:( Problem with new hardware: MSI 890GXM-G65 + AMD Phenom II 1100T
Olawles
My problem deals with a few different topics so I apologize if this is miscategorized, I just feel this is a motherboard/CPU issue.
I got this bundle deal as I was looking to upgrade both pieces of hardware. http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.679668
After freshly installing everything yesterday, I didn't have any problems whatsoever...now, a day later, I'm seeing the following problems emerge.
1: When I start up the computer I cannot enter the BIOS...I never see an option, and when I press the key to enter it (Del) the startup process freezes and I'm forced to restart.
2: When I open a game (Battlefield: Bad Company 2, Fable 3, etc) in fullscreen, the game opens into a black screen. The sound works, and I can even click on things by guessing where the pointer is, but no visuals whatsoever, and I'm forced to restart.
3: When watching an online video (Youtube, Facebook, etc) there is no sound.
4: On top of everything, the computer boots up slower than it did with my old CPU/motherboard combo.
Note: I just used the Easy OC Lite that comes included with the motherboard to raise my CPU speed to ~3.8Ghz, no issues, no drastically noticeable change.
I thought I had missed some vital driver or something, but I can't seem to find any that I haven't already installed. I have no idea what's wrong so if anyone could offer any helpful input it would be immensely appreciated!
5
answers
Last reply
More about problem hardware 890gxm phenom 1100t
henydiah said:what is the default system has problems too ...?
Are you asking if I had these issues with my old motherboard and CPU installed? No, and I didn't have them when I first finished installing the new motherboard and CPU. That's why I'm thinking it's an issue with the new hardware, and possibly how it's interacting with my existing hardware.
Thought: could it be an inadequate power supply?? -
Ok well I figured most of it out.
1: I'm not sure why the comp would freeze when I pressed any key during bootup but I learned that I have to hold the Del key down when I turn on the computer to get into the BIOS. Worked fine, no more issues with that.
2: Apparently Steam has had a black screen at launch issue for the past few years and it's just part of the Steam experience. I just have to run the games from their actual locations instead of using the steam client to launch them.
3: I don't know what fixed it, but online videos have sound again...I think it may have just been the videos not loading all the way because of a slow i-net connection.
4: Startup time has improved a bit, definitely a lot better than before.
All in all, every problem I had has been, for the most part, corrected. I am definitely going to look into getting a new power supply because if there's any chance of that being the cause of those problems I'd like to upgrade it before it causes problems later on. Thank you for the insight, it is greatly appreciated
Related Resources
Chipsets
Hardware
Motherboards
Product
Related Resources
- Hardware Problems
- Recently my AMD Phenom II X4 945 3.0Ghz runs at 800mhz
- Motherboard for a AMD phenom ii x4 920?
- Amd Phenom ii 955 and Asus m4a785-m problems
- [New System] Hardware Problems
- Friends say this maby be hardware or memory problem
- Phenom II X4 965 BE OC
- OC'ing my phenom II X4 970 BE
- Phenom II + 690G AM2 (M2A-VM) = Works
- And Phenom II hit's 6.5
- BSOD on mature hardware after reformat/install
- Hardware Interrupts...
- Phenom II X2 550 turns into a Phenom II X4 B50
- Core i3 or Phenom X4 965
- Phenom II X4 955 BE or i7 920?
