I have an Asus m4a88t-v evo motherboard and i am using a amd phenom ii x4 processor i have hooked up the hard drive, optic drive, cpu, power supply(20+4 pin and 8 pin) i have also attached memory compatible with the system.
when i turn on the power strip the standby light on the mobo comes on, however when i press the power button on the front it never starts up completely. i dont know if the button is ad or if i missed something or there is a trick to this but i am stuck.
i tried taking out the memory, unplugging some of the uneeded fans, as well as double checking all the connections. can somebody please help me out. if its any constellation the case i am using is a smilidon raidmax case with a 500 w power supply.
