Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > [Solved] Soundcard SPDIF vs Graphics Card Sound via HDMI. SPDIF vs HDMI??
Forum CPU & Components : Sound Cards [Solved] Soundcard SPDIF vs Graphics Card Sound via HDMI. SPDIF vs HDMI??
Best answer from gamerk316.
Sorry if this has been asked before, but I couldn't find any answer.
I have an AVR powering my 7.1 surround theater setup at home. I'm looking to eventually get both of the following:
HT | OMEGA Claro Halo XT Soundcard
http://www.newegg.com/Product/Prod [...] llFullInfo
EVGA 768-P3-1360-TR GeForce GTX 460
My questions are
1: Will these two conflict horribly sound driver wise?
2: How about for surround sound in games such as half-life 2.
3: Is it better to go with the SPDIF Out of the sound card to my AVR or the HDMI from the video card to my AVR?
Very confusing. I'd like 5.1 and 7.1 support.
Reply to silenkiller
Best answer
1: Not likely (VERY unlikely in fact; I have my ASUS Xonar D2 and my sound drivers for both my onboard and 4890 realtek chipset installed, with no conflicts)
2: Both will do surround no problem; its the game sound engine that determines what level of surround sound is supported, not the soundcard.
3: With SPDIF, you are limited to only three formats: 2.0 uncompressed audio, Dolby Digital, and DTS. Assuming you have decoding support for either Dolby or DTS on your AVR (which you almost certainly do), you can enable either Dolby Digital Live or DTS-Connect (or DTS:Neo PC, depending on what there're calling it) from the soundcard to enable the real-time conversion of uncompressed 5.1 audio to either of these formats, giving you the ability to output 5.1 over SPDIF.
With HDMI, you can simply set your output to 5.1/7.1, as HDMI has the necessary bandwidth to pass through uncompressed surround sound audio.
The soundcard, even using SPDIF, will give better quality, but not as much as an analog hookup would give. (For audio, analog > digital). If you want to use 7.1 with the Halo XT though, you HAVE to go analog, as SPDIF simply doesn't have the bandwith to pass through any existing 7.1 sound format.
------------------------------ http://valid.canardpc.com/cache/banner/1647132.png
Reply to gamerk316
Wow thank you for the informative post. Any idea as to whether I can use the HDMI out of the graphics card only for audio and not video? As in, I still want my video to go to my computer monitor, but audio go to my a/v receiver?
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 2100 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 6 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
