Archived from groups: comp.sys.laptops (More info?)
Casper wrote:
> the battery life of our Vaio PCG-GRT996VP seems quite short, about
> 1.5 hours.
> Is this normal?
> Does the Vaio have a memory for battery capacity?
> For Apple notebooks this is well documented issue where resetting the
> memory solves capacity issues
This is normal - actually better than average - for the GRT series. No,
there is no way to reset the battery to improve capacity. Older
computers using nickel-cadmium or nickel-metal hydride batteries
sometimes had a calibration program that reset the 100% charged level as
the total capacity declined with age. These apps did not reset the
charged capacity of the battery.
> 1.5 hours.
> Is this normal?
I failed to add that battery life is a function of many operating
features. For example, a wifi card draws substantial power as does the
display at max brightness. Heavy CPU activity likewise requires
substantial power - this can include background programs, etc.
Improvements in battery life by reducing power consuming activities and
peripherals can be substantial. Shutting down the wireless alone might
add a half hour of operation.
