Hi,
I built my pc about 3 weeks ago, everythings been working fine. Yesterday I changed the thermal paste on the GPU and reinstalled the card. It worked fine for 30 mins and even did a benchmark. After that I had no load on anything and it turned itself off and failed to power up again.
I pressed the on switch which is located on the motherboard and still no power. The only way I can power the system is if I remove the CPU 8-pin plug. I have tried everything I can think of for the moment right up to breadboarding the motherboard with no GPU or hdds plugged in. Also run on one stick of ram. Nothing has worked.
I have also multi metered the PSU and everything seems fine (+12v across each pair on the CPU plug, and a variety of voltages on the 24 pin plug).
The cpu and the gpu were overclocked at the time, temperatures were normal and volts were within specs.
MB: Asus P67P8 Evo
Ram: G. Skill 2133mhz 2x4gb
CPU: i5 2500k
G Card: XFX 6950 2gb
PSU: Seasonic 650km X series
MB: Asus P67P8 Evo
CPU: i5 2500k
