APPROXIMATE PURCHASE DATE: Hoping to order parts within the next 2-3 weeks
BUDGET RANGE: I am already over budget.. I started off with a $500 budget not including the video card. My only choice for a budget now is either get what I am going to list, upgrade something (ie: RAM) for $10 more, or spend less.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, a little bit of video editing, and internet (anything can do this nowadays anyway).
PARTS NOT REQUIRED: I already have several SATA HDDs, a couple of external HDDs, 20" Dell monitor, DVD+/-R RW DL drive, speakers, mouse, and keyboard.
PREFERRED WEBSITE(S) FOR PARTS: Not biased or anything, but.... I only buy from Newegg,
COUNTRY OF ORIGIN: United States
PARTS PREFERENCES: I don't have any preference on parts, but I like manufacturers who have really good warranties and make awesome products so I don't need the warranties. :lol:
OVERCLOCKING: I have never OCed anything, but if the CPU and/or the Video card can be OCed safely and easily.... maybe.
SLI OR CROSSFIRE: No SLi, at this time... in the future... I don't know.
MONITOR RESOLUTION: Right now it is at 1680x1050. I am not 100% sure what the max is on this monitor, but I will more than likely upgrade to something bigger within the next year. Plus I do have the ability and wiring to hook the PC up to my 47" LCD TV.
ADDITIONAL COMMENTS: I have never built an Intel PC, and the last AMD PC I built was probably back in 2004 or so... I want to be able to not worry for awhile about upgrading anything, because as it stands right now my wife just wants me to shut up about building a new PC, so the longer it is before I need to build another one... the better.
What I have so far...
Case $90 : COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
PSU $130 (before rebate) : CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
Motherboard $220 : ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
CPU $300 : Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
Video card $480 (before rebate) : EVGA 015-P3-1480-AR GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130552
RAM $90-$110 : Here is where I am just a little bit confused. I want to get 4GB for now, but I will only be using a 32-bit OS (please don't yell at me ), because I really don't like dealing with having to find 64-bit programs for the stuff I use. I will only upgrade to 64-bit OS if people think that having a 32-bit OS is limiting (bottle-necking) the hardware.
Regarding the actual kind of RAM I want is what is confusing... according to Newegg's site the motherboard I picked out doesn't list the DDR3 1600 speed, but only "DDR3 2000 (O.C) / 1866 (O.C) / 1333", so does that mean I can't get 1600 speed RAM? I have looked at Corasir's Dominator line at Newegg and I see two different model #s, but I can't tell which one is better... or if I can even use them...
Here is the comparison link: http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007611%2050001666%20600006050%20600006066%20600006127&IsNodeId=1&bop=And&CompareItemList=147%7C20-145-249%5E20-145-249-TS%2C20-145-323%5E20-145-323-TS
Additional Comments:
I talked about my RAM "picking out" problem, but I have a few other things I need to ask.
I was on the fence for awhile about the video card. I kept asking myself, "Should I get the GTX 470, or go ahead and get the GTX 480?" I finally settled on putting the GTX 480 here for opinions. My "OHHH" factor comes from looking at: http://www.videocardbenchmark.net/high_end_gpus.html
In your opinion, do you think the motherboard will cause the Video card to bottle-neck?
Is the PSU good enough for the video card? The card's details say this: "Minimum of a 600 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 42 Amps.) "
I want to be able to play the new FFXIV (Final Fantasy 14) without worrying too much about the game running like crap.
Here are the specs for the game:
CPU: Intel® Core™ i7 (2.66 GHz) or faster
RAM: 4GB (or higher)
Video: NVIDIA® GeForce® GTX 460 with 768 MB VRAM or equivalent
I have been playing the open beta on my Dell XPS 410 ( Intel Core 2 CPU 6600@2.4GHz, 3GB out of 4GB of RAM showing (32-bit Win7), and GeForce 8800 GT (512MB)), and it running OK... except for the fact that the game play is very choppy and on the benchmark test for the game I scored a 2700-3000 out of a possible 7000 (I think 7000 was max).
How do you think this new build will look compared to what I am seeing now? (Not actually "seeing" but performance wise.) I won't hold you to your opinions.
Are there any problems with this build? Is it possible for me to make the build less expensive without taking away performance?
I thank you for helping me out, and hopefully I didn't ask any stupid questions.
Thanks.
Thanks.
