Network places problem
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I am on ADSL always on. When I open network I can't find anything, also
when I check in system to see if my Ethernet card is working it is not even
shown, although it is all working and I am able to use the net. If I try
ipconfig, it shows all the information but I can't find it in windows so
that I can adjust the properties. I am using XP Pro. Can anyone help
please?
More about : network places problem
Why would you want to change properties if everything is working ??
You can find some of the settings by using Start ---> settings - network
connection and then right click on the connection icon.
Some of the settings can be found by using Start -->control panel --->System
Icon.
Then click on computer name
And the ones for the interface card itself by clicking on hardware -->
device manager and expanding network adapters.
Jon Hildrum
DTS MVP
Jon_Hildrum@msn.com
www.hildrum.com
"barrie" <basser@tiscali.es> wrote in message
news:%236jxcBdjFHA.1044@tk2msftngp13.phx.gbl...
>please?
That is my point, I have tried all that you have suggested and cannot find
an icon.
"Jon_Hildrum" <Jon_Hildrum@amsn.com> wrote in message
news:elODLYejFHA.2472@TK2MSFTNGP15.phx.gbl...
> panel --->System Icon.
> Jon Hildrum
> DTS MVP
> Jon_Hildrum@msn.com
> www.hildrum.com
>>even shown, although it is all working and I am able to use the net. If
>>I try ipconfig, it shows all the information but I can't find it in
>>windows so that I can adjust the properties. I am using XP Pro. Can
>>anyone help please?
The icon is likely to say something like
Local area connection (and it might provide the interface card below)
Jon Hildrum
DTS MVP
Jon_Hildrum@msn.com
www.hildrum.com
news:%23SsrgpejFHA.3332@TK2MSFTNGP10.phx.gbl...
> an icon.
>> Jon Hildrum
>> DTS MVP
>> Jon_Hildrum@msn.com
>> www.hildrum.com
>>>anyone help please?
This is my point, I know what the icon might say, but there is no icon,
neither is there an entry in system/hardware for my card, yet still it
works!
news:eW7bimjjFHA.2916@TK2MSFTNGP14.phx.gbl...
> Jon Hildrum
> DTS MVP
> Jon_Hildrum@msn.com
> www.hildrum.com
>> find an icon.
>>> Jon Hildrum
>>> DTS MVP
>>> Jon_Hildrum@msn.com
>>> www.hildrum.com
>>>>also when I check in system to see if my Ethernet card is working it is
>>>>not even shown, although it is all working and I am able to use the net.
>>>>If I try ipconfig, it shows all the information but I can't find it in
>>>>anyone help please?
> no icon,
> still it
> works!
> card below)
> > Jon Hildrum
> > DTS MVP
> > Jon_Hildrum@msn.com
> > www.hildrum.com
> and cannot
> >> find an icon.
> working ??
> settings - network
> -->control
> hardware -->
> >>> Jon Hildrum
> >>> DTS MVP
> >>> Jon_Hildrum@msn.com
> >>> www.hildrum.com
> anything,
> working it is
> to use the net.
> can't find it in
> XP Pro. Can
> >>>>anyone help please?
You sure it’s ethernet?
The "symptoms" you describe make me think that it’s a USB adapter,
with some kind of specilizsed software which removes the need for a
network interface compleatly.
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Configuration-Manage-Netwo...
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1318579
Ask the community
