Radeon 5770 display issue (1920x1080) - help please
hi guys, i just upgraded my nvidia 9800gt to an ATI Radeon 5770, and i have a benq e2200 which has a native resolution of 1920 x 1080, however when i use the setting in my propeties > display settings, it says Out of Range! and when i try and run it with my 5770 my screen goes all weird its unreadable blurry and constantly moving up and down at a rapid rate.
before i upgraded my pc i used a nvidia 9800gt, which worked without a problem.
in display settings under monitor its showing Generic Non- PiP Monitor on ATI Radeon HD 5700 Series. im using a DVI to VGA adapter aswell, have Catalyst 10.7 installed, driver for the e2200 also installed
and as verification: screen specifications:
Screen Size 21.5" Wide
Color Glossy Black
Resolution 1920x1080
Pixel Pitch 0.248
Brightness 300 cd/㎡
Contrast Ratio 1000:1 (DCR:10000:1 )
Response Time 5ms / 2ms(GTG)
Display Area 476.64x268.11 (mm))
Color 16.7 million
Viewing Angle 170/160 (L/R;U/D) (CR>=10)
Input Connector D-sub / DVI-D/ HDM1.3 / Audio in / Headphone Jack
Horizontal Frequency 34 ~ 94 (KHz)
Vertical Frequency (Hz) 50 ~ 85 (Hz)
Video Bandwidth (MHZ) 25 ~ 205 (MHz)
Colour Temperature Settings Reddish / Normal/ Bluish / user mode
Power Consumption 45W(max)
Power Supply Built-in
Power Supply 2 x1W
Features
Senseye+Photo
VIsta Premium Certification
Built-in Speakers 1Wx2
Kensington Lock
VESA wall mounting 100 x 100 mm
Adjustments (down/up) Tilt -5/20 (down/up)
Dimensions(W x H x D) 522.8x407.8x186.8 (mm)
Weight 5.2 kg
if anyone can help id greatly apprieciate it
if i cant fix this i might go back to using the 9800
12 answers Last reply
More about radeon 5770 display issue 1920x1080 please
  1. That message is usually a refresh rate issue in my experiance. Usually its set to high for the monitor. Open up the CCC and see where its set. There is obviously something wrong with the drivers of one or other, As the BenQ isnt being recognised i would sugest re-installing the Monitor drivers as well.
    Mactronix
  2. i downloaded the driver from the Benq website last night and put it in c:\windows/system32\drivers. so what else could this issue be. i tried screenshoting the screen with how it acts in 1920 x 1080 but it didnt work, just came up as the clear desktop when i pasted it into paint to save it
  3. What do you mean you put it in c:\windows/system32\drivers. You do realise you need to actually "Run" the driver application so it can install itself ? Its not just some code that needs installing to a directory.
    Mactronix
  4. well i extracted the drivers from the zip file and its not coming up with anything to actually run them
  5. Well you have to run the drivers or you wont get anywhere, What about the driver disc for the Monitor i guess you dont have that anymore ? If so then use that.
    If you can post a screen shot of what you got when you opened your Zipped file i will take a look and soo if there is an exe file or some such so you can run the drivers manually.
    Mactronix
  6. here screenshot of the driver folder i downloaded from benq support
    http://img217.imageshack.us/img217/9804/e2200driverfile.jpg
    as for the driver cd, my monitor didnt have one in the box when i bought it/ and the shop i bought it from is closed down now
  7. just found Powerstrip, which supposedly lets you ''customize resolutions'' however Advaced Timing Options are greyed out so cant even do that lol
  8. Just been to BenQ and couldnt find any drivers so your one up on me there already. What you posted dosent look right at all. If you cant find a set of drivers to download from a third party then maybe you could find a driver disc on Ebay if every thing else fails. You do need the drivers though.
    Mactronix
  9. max rlution i can get is 1600 x 1200
  10. Quote:
    downgrade to previous driver.proably cat10.3.Then connect ur monitor to the second dvi port of ur card.If this donot help i smell a bad card RMA it.
    the a did not work either :(
    ive gone back to using my 9800GT and all is fine now....called up Benq, will try again when i get the driver CD
  11. trying my 5770 after bad fps performance, seem to have misplaced my receipt for it, if it doesnt work when i get the cd for the monitor drivers ill just go buy a nvidia equivilent
    downloaded the Benq driver installed it with going to device manager > monitors > properties > update driver > have disk > "browsed to the location" > next > then reset and no change
  12. ignore this edit
Graphics Cards Radeon Graphics Displays
