Solved
New Builder Office Build Help
This forum is great! Just a beginner, but have learned a lot through reading these posts.
Have been reading for awhile and now feel its time to jump into my first build. Interested in building a budget home office computer that I can also use for some simple graphic design (Indesign), photo editing (LR and Photoshop) as well as some basic audio functions (Itunes, etc). I would like to possibly be able to edit video in the future.
Office functions include word processing, web surfing, multiple windows and some light finance trading.
I have a pretty large photo and audio collection and would like to keep a good portion of it on the build in addition to my external.
Ideally, I would like to have a dual monitor setup if possible. I will not need to purchase the monitors, keyboard, mouse or any software.
Obviously I value reliability and would like the build to last for a bit!
This is the build I pulled from the sticky section: (Thank you/ all credit to daveg)
Processor:
AMD Athlon II X4 640 - $106
More than enough for workplace multi-tasking.
Motherboard:
Gigabyte GA-MA78LM-S2H mATX - $65
Built 5 of them. They just work great. Huge deal ($25) when combo'd with Athlon 2 X4's at MicroCenter.
RAM:
A-Data 4GB (2x2) DDR2 800 Kit - $79
No need for more.
Graphics Card:
Asus 8400GS 512MB Silent - $33
Passive cooling for silence and more than capable enough for dual monitor use.
Hard Drive:
WD 320GB - $50
Solid reliability. Small-ish capacity for easy/quick back-ups and/or cloning. Less fragile than larger capacity drives (again, because people neglect their computers (physically).
Case:
Cooler Master 341 mATX - $40
Built in dust filter on front for coworkers to neglect on their cleaning duties.
Power Supply:
Antec EarthWatts 380 - $45
Reliable, powerful enough for expansion and efficient.
DVD Burner:
LG Sata DVD Burner - $18
It's an optical drive.
This build was around $450 and I would probably be able to go up to $600 if needed.
Any other recommendations/ additions to add to this in for my purposes?
Thanks again this forum is really great.
12 answers Last reply Best Answer
More about builder office build help
  1. Best answer
    ^ You have really got a very good build there...
    Some suggestions -
    1. Video card, I would suggest this, though I doubt for your usage, it would matter but these are newer and better
    PowerColor Go! Green AX5450 512MK3-SH Radeon HD 5450 (Cedar) 512MB 64-bit DDR3
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814131339
    2. RAM - Why not the Mushkin's for the same price ?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226092
    Or even cheaper -
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820146748
    3. HDD - IMO the Samsung F3s would be a good choice -
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
    4. How about these cases with the PSU combo on newegg ??
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492902
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492925
    5. Mobo - Maybe the newer chipsets ? but that choice is fine for your needs though...
  2. Thanks for the great suggestions gkay.
    Here is what I am thinking with a few options/ changes:
    Processor:
    Motherboard:
    Unless any new suggestions?
    Maybe something like this:
    ASRock 870 EXTREME3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD $89
    Ram:
    Mushkin Enhanced Silverline 4GB (2 x 2GB) $80
    Graphics Card:
    OR
    PowerColor Go! Green AX5450 512MK3-SH Radeon HD 5450 (Cedar) 512MB 64-bit DDR3 $40
    Really not to sure of the difference/ benefits of each.
    Hard Drive:
    SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" $55
    Case/ PSU:
    Antec Three Hundred Black Steel ATX Mid Tower Computer Case w/Antec EarthWatts Green EA-380D Green 380W $75
    DVD Burner:
    Also I would like to add a wireless adapter if there are any suggestions.
    Thanks again
  3. ^ Actually the HD 5450s are about 2 generations newer and in terms of raw power, are certainly higher, so go with 5450...
    Mobo + RAM -
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.509375
    CPU + DVD
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.494569
    Wireless adapter - maybe this one ?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16833320040
  4. Great! Thanks for the suggestions and combos.
    I have seem some guides here online on the build process, but was wondering if there is anything else (extra fans, cables or adaptors) I will need to help the first build go smoothly.
    Thanks again for everybody reading and the suggestions.
    CCH
  5. ^ I dont think you would need any additional cables as of now, your mobo would come with atleast 2 SATA cables, that would suffice for the HDD and the DVD...
    Good luck with your build...
  6. ^ The EcoGreen is a storage drive rather than a boot drive i.e., it would be slower because of the lower rpm...
  7. Ok everything is in and connected. I ran into some trouble while trying to install Win9 64 bit and any help would be greatly appreciated.
    While I was first trying to install I kept getting the blue screen during the unpackaging phase. After formatting the HD i was finally able to successfully install the OS. The only problem now is that every 5 mins or I get that screen for 3-4 seconds followed by a restart.
    Any idea how to fix this.
    Also I updated the latest BIOS version. Do I need new mobo drivers?
    Thanks for the help,
    CCH
  8. Academic if u had already bought parts but i would have just jumped from non Universal Video Decoder (UVD) Radeon 3000 IGP on that 760G and hit a entry level 880G with HD 4250 IGP rather than hit low end GPU?
    $310AR
    Optional : 60GB Sandforce based SSD $120AR
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820227542
    or if down the road your apps leverage on GPU acceleration
    GTS 450 $120 Free Ship
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814187120&cm_re=GTS_450-_-14-187-120-_-Product
  9. Unfortunately I already bought the components, but thanks anyway.
    So when I remove one of the RAM sticks no more BSOD. Can anybody help?
    With both of them in the mobo it was a BSOD on just about every start up. Is there a setting to change so I can have both of the 2gb sticks in?
    Thanks
  10. OK here is the update. Any advice is great appreciated.
    It seems that running Windows 7 with 1 Ram stick is stable, but I still get the BSOD.
    How do i get this system running reliably?
    I have run the memtest, updated the bios, manually set the timings and nothing really seems to work.
    Any ideas?
    Bad RAM?
    Thanks,
    CCH
  11. Best answer selected by chuggs.
Build Office Systems Product
