I made my way down to my local computer shop and ordered my pieces. I have alot left over from my previous pc (screen, secondary HD, etc.).
Here's what I ordered basically,
1. amd Phenom II x4 965
2. Crosshair IV
3. xfx HD 5870
4. hx1000w by corsair
5. 8gb mushkin redline ram 1600
6. Corsair 128gb ssd
7. Antec DF85 case
8. Lite-on DVD burner
9. Death adder and lycosa keyboard and mouse combo
I can still change my mind before I pay and go with something else.
My main concerns are with the building of the computer, I think I have the parts down... do correct me if I'm right.
First concern/question. CPU: Thermal paste or not? Do I need to apply some to the cpu after having installed it or should I not bother? I've read both and I'm really just wondering.
Second concern, the ram runs at 1600 and the board at base runs at 1333. Now from what I understand it only means my ram will run cooler then it should and that I shouldn't bother OC'ing it until the need is present. Will my timing still be 6-8-6-24? If I don't want to overly complicate my life.... should I just install the darn things and forget about them? Will I run into stability problems if I don't play around with it?
From my understanding the steps roughly are:
1. Install mobo spacers
2. install mobo
3. Install CU
4. INstall ram
5. Install psu and connect everything
6. install ssd/hd and connect sata and ps connections
7. Install GPU
8. Install optics and connect.
9. Make sure everything is connected
10. Start computer and select boot dvd drive to install windows 7 on ssd
Does this sound right? Am I missing anything?
I'm just kinda nervous this being my first build and me not being the biggest tech freak and obviously playing around with almost 2k worth of material. I really want to learn how to make this all work.... tired of being screwed by hp, dell and whoever wants to sell me a computer for twice the price it's actually worth.
Any sites or reading you would reccomend? Any applications that I should get prior to building it? Diag tools for my laptop? Anything?
Thanks alot!
-Grim
2. Crosshair IV
3. xfx HD 5870
7. Antec DF85 case
2. install mobo
3. Install CU
4. INstall ram
7. Install GPU
Thanks alot!
-Grim
