VGA Cooler for my 4850, 3 options help
Hey guys, to get straight to the point, my 4850 reaches temps of 100+ C while playing sometimes and I am desperately in need of a good vga cooler.
Of these 3 which do you guys suggest from 1 to 3: Note that the last link is of one that costs only $19.99 but I have read great reviews from 4850 users stating that temps dropped as much as 20+ also if I could save 40+ dollars without buying the expensive ones that would be a great bonus.... anyways here are the links, and thank you.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1683... $51.99
http://ncix.com/products/?sku=48358&vpn=Twinturbopro&ma... $49.99
http://ncix.com/products/?sku=42005&vpn=AcceleroL2Pro&m... $19.99
Graphics card Authority
Read through the customer reviews and check for any available reviews on the net.. That should solve your dilemma.. Personnely I've never used any replacement cooler ever.. Arctic cooling as a brand though have quality products and good amount of respect.. Besides, 20$ is a decent price for you to experiment..
Graphics card Master
Wait, before that:
1. Are you sure your card is free from dust?
2. Try cleaning your card and re-apply the thermal paste.
3. What model is your HD4850? brand? Is it single slot card?
Ask the community
