Odd boot problem again?
I just put together a new system using the following:
MEM 4Gx2|GSKILL F3-10666CL9D-8GBRL
SSD 64G|KST SNV425-S2BD/64GB R
CPU INTEL|CORE I7 860 2.8G R
MB EVGA 132-LF-E655-KR P55 1156 RT
Antec 900 w/ 650w PS
GPU EVGA 9800 GTX
DVD BURNER LITE-ON | IHAS424-98 R
Windows 7 Home Premium 64bit
I am having a similar boot problem as was addressed in this thread: Tom's Hardware > Forum > Systems > Homebuilt > [Solved] Odd boot problem or not?
When I push the start button the computer starts up as normal, lights come on, fans power up but after 8-10 seconds it shuts down. Then it immediately starts up again and boots normally. I saw the answer to the above post but it mentioned Gigabyte mobos not EVGA ones. Should I be worried or not? I checked my reset switch, and they are all in the right place
1 answer Last reply
More about boot problem again
  1. I have the EVGA FTW3 (X58 chipset) and my computer does that as well, but only if it has been disconnected from power (PSU manually shut off, not just shut down) and the capacitors fully discharge. I haven't noticed an issues because of it. I wonder if it is related to power and the capacitors on the motherboard not being charged up quickly enough.
Homebuilt Boot Systems
