I have an Antec P160 case and an Asus K8V SE Deluxe motherboard. When removing an old power supply I inadvertently removed the front panel sound connectors from the motherboard. They are one of the few things I don't like about the case - they are extremely difficult to attach because they are separated individually and have very little lead wire for each pin. There are 7 wires that have to attach to a 10 pin connector. You can get one on, but when you go to add the next there's not enough wire to maneuver it and the first one comes off. I remember the first time around it took me HOURS and now I don't know how I ever managed to do it.
I am wondering - can someone point me to an extender or something where it would be easier to attach the single wires, and then just push the extender onto the connector on the motherboard? I've done some searching but all I've found are cables. I'm thinking it needs to be a solid one-piece something or other.
Thanks.
Thanks.
