you will be fine .. Basically, there isn't any 'Max' temperature... you want it as low as you can get it. The 'motherboard' temperature reading is not a chipset temperature, just the temperature the 'motherboard' temperature sensor. If you are getting alarms from AsusProbe, set the 'motherboard' temperature threshold to 70c and the alarms will cease.
