Solved
Core i5 build mobo help...
I'm am building my first computer, and I will be using it primarily for gaming. It is going to have a Core i5 sandy in it, and I need help picking out a mobo. What I need is:
LGA 1155
P67 Chipset
2 way Crossfire support
32gb RAM
At least 1x SATA 6gb/s
Enough room for my HIS 6950 2gb card, (and another in crossfire, a little way down the road).
My budget is $180 at most. Thanks in advance.
3 answers Last reply Best Answer
More about core build mobo help
  1. Best answer
    You have a lot of options. I would check out some of these:
    ASRock P67 EXTREME4 (B3) - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229 $159.99
    MSI P67A-GD65 (B3) - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130574 $179.99 (+ $7.87 shipping, so it does go over $180, but their is a $20 rebate, so $159.99) (Also, newegg doesn't list the crossfire, but it is capable)
    ASUS P8P67 (REV 3.0) - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131705 $154.99
    GIGABYTE GA-P67X-UD3-B3 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128488 $154.99
    Those are my quick picks. There are more to choose from, just check out the newegg link below and browse for a bit.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007627%20600093976%20600008069%20600008635&IsNodeId=1&bop=And&ShowDeactivatedMark=False&Order=RATING&PageSize=20
  2. Best answer selected by lukethomas209.
  3. Thank you! I am going to go with the ASRock P67 EXTREME4 because it has very good reviews, and it is $160.
    Thanks again for your help!
Motherboards Core Crossfire Intel i5 Product
