I'm runnin an ASUS p67 deluxe with...
i5 2500k (3.3ghz)
8g ddr3
gtx 570 (1280m)
on a win7 machine
My internal hard drive.... is the same one I've been using for over 5 years now, it's a basic 320g...
It's time for an upgrade.
The trick is, I know very little about SSD's.
So, my main interest is a good mix of reliability and speed.
I've gone so long with a regular old drive, the difference between one SSD and another... speed-wise... is a bit less important than buying one that is reliable, durable, and user-friendly.
My budget restriction is ~200$.
My storage restriction is ~240g.
My top 4 choices at present.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211597
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227808
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148534
http://www.newegg.com/Product/Product.aspx?Item=N82E16820249027
I'd like to know if I'm relatively on target.
Any opinions about which one fits my aim best would be much appreciated.
Also, if anyone has suggestions/ideas other than the 4 I've linked, please let me know.
Thanks in advance.
i5 2500k (3.3ghz)
8g ddr3
gtx 570 (1280m)
on a win7 machine
Thanks in advance.
