GTX 460 Power Question
Will a GTX460 and an Intel Core i7 930 work whit a Coolermaster 620W psu? three +12V rails whit 19amps on each of them.
3 answers Last reply
More about power question
  1. Should do as the GTX460 only needs 160w, did this question really require another thread though?
    sorry didnt saw the answer of your question,thanks for this answer btw,i cant belive a better higher card uses less heat than the gtx260.
  3. Newer cards built on newer fabrication processes(like from 55 nm to 40 nm) use less power and give put less heat than the older cards.
Graphics Cards Gtx Cooler Master Intel i7 Intel Power Graphics
