Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > I5 first build- review and advice
Forum Systems : New Build I5 first build- review and advice
Building my first rig and wanted some advice from more tech sauvy people. Rig will be used for photoshop and other graphics apps, some gaming. looking to buy in about a month, just need to know if im on target here or if i missed the mark. Budgets around 1500 so ive got some room to play with if need be.
Grand Total: $1,367.80
cpu: http://www.newegg.com/Product/Prod [...] 6819115215
motherboard: http://www.newegg.com/Product/Prod [...] 6813131665
ram: http://www.newegg.com/Product/Prod [...] 6820211409
power: http://www.newegg.com/Product/Prod [...] 6817139006
gpu: http://www.newegg.com/Product/Prod [...] 6814130563
monitor: 2x http://www.newegg.com/Product/Prod [...] 6824009266
case: http://www.newegg.com/Product/Prod [...] 6811119137
cd/dvd: http://www.newegg.com/Product/Prod [...] 6827106289
hard drive: http://www.newegg.com/Product/Prod [...] 6822136533
Reply to WTFO
You need to get a 1GB version of the GTX 460. I recommend this one:
http://www.newegg.com/Product/Prod [...] 6814125333
You have chosen a card that can be easily SLI'd, and a PSU that will support two, but your board choice will not.
You have chosen a 6GB/S hard drive but the board does not support that.
Here is a board that will do it all, but not at the same time....
(You can't get a P55 board that will do both SLI and 6GB/S at the same time. Chipset limitation.)
That covers it.
------------------------------ Waiting for an answer? I lost the flag to the post. Send a PM
My Guide to choosing parts
Troubleshooting Guide
PSU Guide
Reply to Proximon
I'd switch the ram to some g skill ripjaws for like $20 more. If $ isn't an issue, maybe consider adding an ssd as well. nice build though. have fun.
------------------------------ http://valid.canardpc.com/cache/banner/1355711.png
Reply to thestrangebrew
Proximon miss-linked, but he may have meant this board at x8-x8:
http://www.newegg.com/Product/Prod [...] 6813131621
or this one at x16-x4:
http://www.newegg.com/Product/Prod [...] 6813128409
HD: you may want to consider this larger, faster, less expensive F3:
http://www.newegg.com/Product/Prod [...] 6822152185
Reply to Twoboxer
Thanks Twoboxer! I actually thought I was linking the less expensive ASRock board though:
http://www.newegg.com/Product/Prod [...] 6813157206
PSU Guide
Reply to Proximon
LOL - figures you'd have something more better up your sleeve!
Reply to Twoboxer
There are 2026 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 2 hours ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
