Hello, is the GE force 6200 compatible with a dell gx270
ko888 Titan Feb 18, 2009 16,708 41 84,990 Aug 8, 2010 #2 What is the case style of your Optiplex GX270 Small Form-Factor or Small Desktop or Small Mini-Tower? Is this GeForce 6200 graphics card, that you are considering, a low profile AGP slot card?
G Guest Guest Aug 8, 2010 #3 its the computer which has 2 buttons at the top and bottom to access the inside
rocky41 Distinguished Jul 21, 2010 719 0 19,060 Aug 8, 2010 #4 A GeForce 6200 is really a week if you have Optiplex GX270 you should better go with an hd 3450 agp...it's 256mb and will outperform 6200 geforce....
ko888 Titan Feb 18, 2009 16,708 41 84,990 Aug 8, 2010 #5 As long as the card is a low profile AGP card it should work.
