I'm building for a friend on a $1200 budget, sans monitor. He will not OC and will use the computer primarily for gaming/internet/music/light work and do not anticipate heavy video/photo applications. Do you see any problems with this build or would you shift money investment around to other components? We are not within a reasonable drive to a MicroCenter. Opinions much appreciated, thank you.
Case: Antec 902 $130
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058&Tpk=antec%20902
PSU: Cooler Master Silent Pro M700 700W $86
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171037&cm_re=cooler_master_silent_pro-_-17-171-037-_-Product
CPU: Intel core i5 760 $210
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067&cm_re=core_i5_760-_-19-115-067-_-Product
Motherboard: ASRock p55 pro $99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157171&cm_re=asrock_p55_pro-_-13-157-171-_-Product
Video Card: PNY GTX 470 $275
http://www.microcenter.com/single_product_results.phtml?product_id=0332959
RAM: G.Skill Ripjaw 4GB (2x2GB) PC 1600 $95
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
Hard Drive: Samsung spinpoint f3 1TB $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=samsung%20spinpoint%20f3%201tb
DVD Burner/CD-ROM drive: LiteOn iHAS-324-98 $25
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106334&Tpk=lite%20on%20ihas-324-98
Sound Card: Asus Xonar DS 7.1 $49
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132013&cm_re=asus_xonar_ds-_-29-132-013-_-Product
Speakers: Logitech S-220 2.1 $30
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121014&Tpk=logitech%20s-220
Mouse: Microsoft Sidewinder $25
http://www.newegg.com/Product/Product.aspx?Item=N82E16826105223
Keyboard: Microsoft Natural Curve $18
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109149&cm_re=reclusa-_-23-109-149-_-Product
Operating System: Win 7 $99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754&cm_re=operating_systems-_-32-116-754-_-Product
Total Cost = $1216
Total Cost = $1216
