Hello I'm building a new machine and I would like some help. I've been doing some looking around on the internet to learn about the individual parts of a computer and I think I've done alright with what I've found so far. My main question is does this RAM work on this motherboard, the only reason I ask is because on the motherboard specs it doesn't say 1333mhz supported and i just want to be sure before i make the purchase
I'll post my entire build so you guys can critique what i have so far and answer my questions. thank you very much
CPU: http://www.amazon.com/Intel-Core-Processor-LGA1156-I5-750BOX/dp/B002KQ5KDY/ref=sr_1_1?ie=UTF8&s=electronics&qid=1284599986&sr=8-1
GPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6488427&CatId=3670
Motherboard: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5521712&CatId=4720
Ram: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6101233&CatId=4524
OS: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=5213932
power supply|body: http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=6490863&sku=S19-4222&srkey=S19-4222
If i made any mistakes with picking out these items please let me know.
My next question is what kind of optical drive do i need with this chassis, in the specs it says 4 external 5.25" Drive Bays; so does that mean I can't use an internal dvd burner? I ask this because the external drives all look weird to me and I don't know if they're supposed to go in a computer or not.
Also would it be more beneficial for me to go for a SSD or internal Sata I don't know the difference between the two + im not sure if ssd drive benefits from the 6gb sata transfer rate on the motherboard
Again thank you for your time ^_^
