Im planning to build a new comp.
either getting a 5870 or 5850 not 100% sure which one i am getting.
getting the amd II x6 1055T (<-- y im getting it still have no idea its just interests me bc of 6 cores for $200 woah!)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231274
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131656
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156063
250gb hdd 7200rpm that i have
dvd +rw drive
i just need to find a psu not sure if the antec 550W that i found would be good enough? might get 8gb of ram instead of 4 and add another dvd writer.
and add a 40gb ssd for the os and office.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
please comment if you guys think that this power supply will be sufficient.
dvd +rw drive
