OK, so I am considering buying a projector (for watching movies, playing some games with xbox controller) and also a graphics card update. I like the look of this OC'ed GTX 460 (http://www.scan.co.uk/Products/1GB-G...-DL-DVI-I-HDMI). I already have a dual monitor set up and I have learned from reviews that Nvidia cards only support 2 displays (I am not considering an SLI system atm).
My question(s):
If I get the 460 and plug in all three displays, will I be able to use my normal dual monitor set up most of the time, and then quickly and easily swap my second display for the projector using onboard software, and have all the settings remembered?
Is it worth spending a bit more for the HD5850 which supports 3 displays at once, but doesn't seem to offer any real performance boost? (Considering that 90% of the time the projector will be disabled and I will never need all 3 displays at once)
My question(s):
