First Time Build: Part selection check/help $1.5k-2k
Hello everyone,
After 5 years of meaning to build my own PC, I'm finally doing it. I've got a fair bit of time for MIR/rebate shopping so I'm mainly looking to see if there's any glaring mistakes I've made in part selection, or something I should change out/watch out for. This is also my first build, so I'm quite excited about this. I've spent a good bit of time researching things on Tom's as well as other places, so I think I've got a decent idea of how to start.
Thanks in advance!
Approximate Purchase Date: Started, I'm picking up pieces as they go on sale/MIR. I should have all the parts by November.
Budget Range: $1500-2000 US
System Usage from Most to Least Important: Gaming(LOTRO, New Vegas, CIV 5, etc.), Video/Media PC, Internet, School/Programming
Parts Not Required:
ASUS VH236H 23 Inch Widescreen LCD Monitor - Black (1920 x 1080)
Keyboard: MS Ergonomic 4000
Mouse: Logitech G9x
Headphones/Speakers: Have several, happy with them.
Windows 7 Professional(64-Bit) OEM
Preferred Website(s) for Parts: NewEgg.com, Amazon.com, TigerDirect.Com
Country of Origin: USA
Parts Preferences: I'm going with a LGA1336 build, prefer NVIDIA/INTEL, no real preference otherwise.
Overclocking: Maybe
SLI or Crossfire: SLI when card prices drop some.
Monitor Resolution: 1920x1080
Additional Comments: This is a build in progress. I'm grabbing stuff as MIR/Discounts pop up. Final build date in November/December at latest. I'm looking for the core of this system to be capable of playing games decently for 3-4 years with some upgrades(GPU, more RAM, SSD) I'll start overclocking if I need it latter down the line.
Parts I already have:
RAM:
OCZ 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3F1600LV6GK
GPU:
MSI N460GTX CYCLONE 1GD5/OC GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
PSU:
CORSAIR HX Series CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS
HD: System drive until I get a SSD
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Parts I'm planning on getting:
Motherboard:
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CPU: There's a MicroCenter nearby that is showing this as ~$50 less for in store pick up, plus with the recent price drop makes this look pretty nice. I don't want to OC initially, so the extra speed is appealing.
Intel Core i7-950 Bloomfield 3.06GHz LGA 1366 130W Quad-Core Processor BX80601950
CPU Cooler: I'm slightly paranoid about heat after having a laptop burn out on me. Not enough for liquid yet.
Prolimatech Megahalems Rev.B CPU Cooler
OCZ Freeze for the thermal compound, has good reviews.
Fans: 3x, two for push/pull on the cooler and another for the GPU shroud. I have NO preference on these. Quiet is preferable, but cooling is a priority.
Scythe S-Flex SFF21G 120mm Case Fan
Case: I like the look, and it's giant.
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
DVD Drive: I'd think it would be hard to mess this up.
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
BluRay: Later down the line I'd look into this, but I don't watch movies much, so unless they start offering games on them more often I don't need it now.
Sound Card:
I'm completely lost on this one. I'm planning on just using the integrated audio at first, but if it's not good enough/sound is "poppy" I'll look into this. I'd figure that anything with a front bay control would be fine.
Storage: For bulk storage, add as I need more.
Western Digital Caviar Black WD2001FASS 2TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1 answer Last reply
More about first time build part selection check help
  1. ^ CPU Cooler - Maybe this one ? Current best...
    http://www.svc.com/silverarrow.html
    Mobo - Check this ASUS board - with HDD combo...
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.505960
    And case fan - The Thermalright has the same tech and is cheaper
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835109027
Build Systems
