New Build running Extremly Hot....HELP!
Hello All,
I just built my first pc for video editing and have not even loaded Windows was just playing around in the bios and was warned upon startup that pc was running hot. Below are my system specs.... Please let me know what to do and I would like to stay away from liquid cooling.
CoolerMaster Cosmos S
Front: 120 x 25 mm fan x 1 / 1200 rpm / 17 dBA,
Top: 120 x 25 mm x 1 / 1200 rpm / 17 dBA (supports 120 mm x 2) (optional)
Rear: 120 x 25 mm fan 1 / 1200 rpm / 17 dBA
Side: 230 x 30 mm fan x 1 / 900 rpm / 150 CFM
1 x ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard
1 x CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
1 x CORSAIR DOMINATOR 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model CMD8GX3M4A1333C7
1 x MSI N250GTS Twin Frozr 1G GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
(With nothing running, just in Bios)
CPU Temp: 77C (has reached 80c)
MB Temp: 32C
CPU Fan Speed: 2008RPM
CPU Voltage: 1.216V
I get nervous and shut the box off immed. as I am afraid to cause damage.
Any Suggestions would be greatly appriciated!
Thanks All!
9 answers Last reply
More about build running extremly help
  1. Remove the CPU fan, make sure there is thermal paste on the CPU, then reinstall the CPU fan. Make sure it's on secure.
  2. Hello All,
    MB Temp: 32C
    CPU Voltage: 1.216V
    Thanks All!
  3. can you post a pic side view case open please
  4. I would guess that your heatsink isn't secure. Are you using an aftermarket cooler or the heatsink that came with the processor? Check to be sure it's making good contact with the CPU's heatspreader. Tighten the bracket (for aftermarket) or make sure the intel push-pins are in the locked position (for stock heatsink).
  5. did you use thermal paste? :P
  6. This next topics has been merged by Aford10
    New Build Running Extremly Hot
  7. Thanks for the reply and feel really silly, but.....
    I really could have sworn the paste was already on the unit so did not bother putting any other on.....Any recommendations on which to use or are they all the same?
    Thanks!
  8. A layer of thermal paste should have come on the CPU fan. Check to make sure before adding more.
    I use Arctic Silver 5.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
    Thanks!
    Are you using the stock intel heatsink? The one that came with the processor? If so, it did already have thermal interface material applied on the bottom. That narrows your problem down to securing the heatsink properly.
    Turn the four corner knobs in the direction of the arrows on them until the white things on the back are spread apart and your heatsink is tightly in place. Check the instruction manual that came with your processor.
New Build Systems Product
