Temperature problems
Speedfan recognizes one of my temperatures (temp2) as 92C but the system is running fine.
GPU is 40C and CPU is 28C
temp1 is 34C
temp3 is 37C
i dont understand where the temperature reading is from
Specs:
AMD 1090T on stock heatsink/fan
8GB 1600Mhz ADATA RAM
gigabyte 480 gtx
intel x25 SSD
WD scorpio blue 1TB 7200rpm
rosewill 1kw psu
antec 1200
windows 7 ultimate
4 answers Last reply
More about temperature problems
  1. You forgot to include your motherboard... It could be a temp issue with your North/South Bridge heat sink. Also, it could just be a false reading coming from Speedfan... meaning it is not actually reading a temperature.
  2. ah. sorry, my motherboard is MSI NF980-G65
  3. It looks like the SpeedFan is picking up a "false" reading. It thinks something is there but isn't really reading anything. I would just hide that reading and don't worry about it. Also, I would recommend CPUID's HWMonitor instead. In my experience, it has been more reliable at showing accurate temps.
    i also checked with the hwmonitor, same thing, temps range from 86-95C
    i think it's a problem with the sensor itself, since the temps at boot read ~90C and start fluctuating right after booting into windows after cooling overnight
New Build Temperature Systems
