Tom's Hardware > Forum > Windows XP > Configuration & Customize > MS scanner and camera wizard problem
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
Can someone please explain this in plain non-techie English? My Microsoft
Camera and scanner Wizard no longer comes up when I insert the FLASH-CARD
from my HP digital camera in the FLASH-DRIVE on my PC. Nothing happens now!
It worked great for 2 years.
How do I get the wizard back so I can unload my camera using the flash-card
in the flashdrive?
I have WXP-Home/SP2. I downloaded some XP security updates but don't know
if they caused the problem.
Thanks........
Sponsored Links
Model of digi cam?
Tried the other way, installing your digi cam software, as per HP bumph.
ie not relying on winxp to do it for you?
"~ FreeSpirit ~" <spammenot@nospam.net> wrote in message
news:OEihQlmlFHA.3568@TK2MSFTNGP10.phx.gbl...
now!
flash-card
> in the flashdrive?
> Thanks........
Reply to dl
"DL" <dl@spoofmail> wrote in message
news:%23eiG%23pqlFHA.2852@TK2MSFTNGP15.phx.gbl...
> Model of digi cam?
## HP 315.
## The software was installed using the HP camera's CD. What is a bumph?
This camera and the MS wizard worked perfectly together for 23 months -
until I installed a critical update. But I don't know which one.
## Not when we have CDs that come with hardware........
FS~
>> Microsoft
> now!
> flash-card
>> in the flashdrive?
>> know
>> Thanks........
Reply to Anonymous
- 0 +
Bumph - software/hw instructions ( an English,UK, expression)
Any updates on HP site? It is not uncommon for apps/drivers to require
updateing to work with SP2
news:usvaGexlFHA.708@TK2MSFTNGP09.phx.gbl...
> > Model of digi cam?
> ## HP 315.
> FS~
> >> Microsoft
FLASH-CARD
> > now!
> > flash-card
> >> in the flashdrive?
> >> know
> >> Thanks........
Reply to dl
news:uWlzRu0lFHA.2472@TK2MSFTNGP15.phx.gbl...
Yes, but there is no mention that they're to update the flash-card to bring
up the MS camera wizard when the flashcard is inserted in the flashdrive.
Also, it's like flashing the BIOS on a PC, one mistake and my $265 camera is
a door stop. Plus the problem existed before I downloaded SP2. I
downloaded a few critical updates before that but don't know which one
caused the problem with the MS wizard/flashdrive.
FS~
>> > Model of digi cam?
>> ## HP 315.
>> > bumph.
>> FS~
>> >> Microsoft
> FLASH-CARD
>> >> happens
>> > now!
>> > flash-card
>> >> in the flashdrive?
>> >> know
>> >> Thanks........
Reply to Anonymous
- 0 +
I didnt mean camera firmware, just their software/drivers
What make of Flash drive is it?
What make/model PC or mobo
Youve tried in win hardware, removing the flash drive, then rebooting to
allow win to reinstall?
Does your Camera manu offer any Tech support, though they will probably
simply blame the o/s
news:uVJiGCAmFHA.3304@tk2msftngp13.phx.gbl...
bring
is
> FS~
> >> > Model of digi cam?
> >> ## HP 315.
> >> > bumph.
bumph?
> >> FS~
> >> >> Microsoft
> > FLASH-CARD
> >> >> happens
> >> > now!
> >> > flash-card
> >> >> in the flashdrive?
don't
> >> >> know
> >> >> Thanks........
Reply to dl
news:e04VTzDmFHA.1372@TK2MSFTNGP10.phx.gbl...
## The only software driver I found was for the camera itself, not the PC or
flash-card.
## It just says "Smart Media Compact Flash." The PC itself is a HP.
## Mobo unknown but I can look that up. The model is a HP a250n. (The
camera is also a HP.)
## No! I never thought of that. How/where do I find win-hardware? I'm
willing to try it for all the hours of time the wizard saves me when working
with pics. I sure can't screw it up any worse. :-)
## No. I have it over 2 years now. I'd pay out the Kazoo if I called HP
for info...... and yes, the OS is usually blamed - or the Critical Updates.
They have you uninstall all of them first,... I don't even want to go there.
FS~
> bring
> is
>> FS~
>> >> > Model of digi cam?
>> >> ## HP 315.
>> >> > bumph.
> bumph?
>> >> months -
>> >> FS~
>> >> >> Microsoft
>> > FLASH-CARD
>> >> >> happens
>> >> > now!
>> >> > flash-card
>> >> >> in the flashdrive?
> don't
>> >> >> know
>> >> >> Thanks........
Reply to Anonymous
- 0 +
The HP site, for your PC, list numerous updates, including Bios and an
update for the KYE 6 in 1 Card reader.
There is also an HP article on card reader problems.
To remove, in win, the device;
Start/Control Panel
Double click 'System'
In new Sys window, Hardware tab
Device Manager Btn
Look for the KYE card reader, in the resulting device listing. You may have
to click "+" to expand a branch.
When Found, highlight, uninstall, then reboot sys
news:ehWYNULmFHA.1464@TK2MSFTNGP14.phx.gbl...
or
> flash-card.
working
Updates.
there.
> FS~
require
> > bring
flashdrive.
camera
> > is
> >> FS~
> >> >> > Model of digi cam?
> >> >> ## HP 315.
> >> >> > bumph.
> > bumph?
> >> >> months -
> >> >> FS~
> >> >> >> Microsoft
> >> > FLASH-CARD
> >> >> >> happens
> >> >> > now!
> >> >> > flash-card
> >> >> >> in the flashdrive?
> > don't
> >> >> >> know
> >> >> >> Thanks........
Reply to dl
news:%23ctL41NmFHA.1968@TK2MSFTNGP14.phx.gbl...
## I can't afford the $150+ the PC techs charge here to flash the BIOS.
and an
## What would that have to do with the MS wizard?
## For the MS wizard????
> Start/Control Panel
> Device Manager Btn
## OK. I have that open now.
## Even expansing or extending them there is no KYE readers of any kind.
You may have
## Yes, I did that. Are you talking about a Generic USB readers under Disk
Drives? There are 4 of those under Disk Drives but none are KYEs.
## Not there! I looked twice to make sure - no "KYE card readers" with
everything expanded - only USB readers. They are listed as CF reader, MS
reader, SD reader and SM reader. Which should I delete? This is right from
the Device Manager window.
FS~
> or
>> flash-card.
>> > to
> working
>> HP
> Updates.
> there.
>> FS~
> require
>> > bring
> flashdrive.
> camera
>> > is
>> >> FS~
>> >> >> > Model of digi cam?
>> >> >> ## HP 315.
>> >> >> > bumph.
>> > bumph?
>> >> >> months -
>> >> >> FS~
>> >> >> >> Microsoft
>> >> > FLASH-CARD
>> >> >> >> happens
>> >> >> > now!
>> >> >> > flash-card
>> >> >> >> in the flashdrive?
>> > don't
>> >> >> >> know
>> >> >> >> Thanks........
Reply to Anonymous
- 0 +
The wizard is'nt working because it does'nt see any device, which could be
for a number of reasons.
ie software/driver/bios/firmware/hw issues
delete all these, then reboot
from
Then in Start/Control Panel look for Camera/Scanner double click, what does
it list?
Reply to dl
news:OHEAheZmFHA.1148@TK2MSFTNGP12.phx.gbl...
> from
> does
> it list?
DL, you've got the patience of a saint...
....but consider this: the normal, expected behavior of an XP system to a
flash card, memory stick, or whatever, would be to recognize that item as a
removable drive, a solid state drive, or whatever terminology the particular
computer uses. A memory card is just that...a generic removable storage
device -- it is not necessarily from a camera, and as such, the camera and
scanner wizard popping up would be the wrong behavior for Windows.
If the camera and scanner wizard was popping up before, it had to be
something that was installed for the camera, or perhaps something written on
the memory stick that changed the default behavior (removable drive) to
having the camera and scanner wizard appear.
So, trying to fix the "problem" through Windows probably isn't going to get
you anywhere as Windows is doing as Windows is supposed to do -- it's
"seeing" a removable drive. If the OP wants a different behavior or override
the normal Windows behavior, the OP is going to need to reinstall/update
whatever program or file caused the change to begin with.
Reply to Anonymous
- 0 +
Yea, suggested the reinstall
OP claims to have done this as per.
Suggested updates OP doesnt seem to want to, seems to think the wizard works
on its own
cest la vie
"D.Currie" <dmbcurrie.nospam@hotmail.com> wrote in message
news:3lhp0jF12sh5lU1@individual.net...
be
with
MS
> > from
> > does
> > it list?
a
particular
on
get
override
Reply to dl
news:OsNxmskmFHA.2444@tk2msftngp13.phx.gbl...
>>> be
>>>> with
>>>> MS
>>> from
>>> does
>>> it list?
>> a removable drive, a solid state drive, or whatever terminology the
>> particular computer uses. A memory card is just that...a generic
>> removable storage device -- it is not necessarily from a camera, and as
>> such, the camera and scanner wizard popping up would be the wrong
> ## When the flash-stick from the camera was inserted before, a window came
> up asking me what I wanted to do and I would choose "Copy pictures to
> folder using MS scanner and Camera wizard." The wizard then came up and
> took over from there....... Now when I make that selection the wizard
> does not come up.
>> on the memory stick that changed the default behavior (removable drive)
>> to having the camera and scanner wizard appear.
> ## See above.
>> get you anywhere as Windows is doing as Windows is supposed to do -- it's
>> override the normal Windows behavior, the OP is going to need to
>> reinstall/update whatever program or file caused the change to begin
>> with.
> ## The only changes were the MS updates. I haven't added or changed
> anything on this PC to cause this problem. I've added no new software nor
> have I deleted any before the problem started. I reinstalled the cameras
> software but that didn't help. The wizard no longer comes up when
> selected.
> Perhaps I'm not explaining the problem clearly enough.
> FS~
All along you've been saying that you want the Camera and Scanner wizard to
automatically pop up when you insert a flash disk; now what you're saying is
that you want the box that pops up and offers you choices as to what to
do -- open a folder, run the wizard, etc. etc. That's a completely different
thing.
So no, you haven't been explaining the problem clearly.
Reply to Anonymous
- 0 +
There have been posts in other groups of problems with the HP supplied card
reader.
If your Epsom scanner isnt listed, then it would appear not to have been
installed correctly
Presumably your HP camera was supplied with a cable to directly connect to a
usb port?
With the camera switched on - card in, connect this.
If your HP Camera software was correctly installed a seperate window/app
should start. This will be a HP Camera specific app - not any winxp wizard -
If nothing happens, either your camera software isnt installed correctly, or
with the camera switched on go back to Control Panel/Camera Scanner,
highlight the entry for the Camera, right click properties. In the resulting
window 'test'
What does it say?
news:eRNNZokmFHA.3020@TK2MSFTNGP10.phx.gbl...
be
with
MS
> > from
> > does
> > it list?
> ## It lists my HP Photosmart 350 and my Logitech QuickCam Messenger
Camera.
> I don't see my Epson scanner listed.
> FS~
Reply to dl
news:e9qYFMnmFHA.2472@tk2msftngp13.phx.gbl...
> card
> reader.
> installed correctly
$$ What makes you say that since it's worked on this PC as long as the
camera has? I have the parser from Epson for it to work with XP. *I just
checked it to make sure it's working - it is!!! :-))) I don't use the
scanner as much now that I have the digital camera.
> a
> usb port?
$$ Yes. That was used before I got the PC with XP-Home. We don't like
using the cable because it really drains the batteries down.
> wizard -
$$ Yes, that window comes up (as long as I don't check the box saying to
remember to do this action each time - now) but if I select the "MS scanner
and camera wizard" as I've done for the past 2 years, it does not come up
anymore. I have to download and delete all the pics manually, then name the
group, etc. It takes forever compared to the speed of the MS wizard.
> or
In the resulting
> window 'test'
> What does it say?
$$ I can't test it that way. I can't click on *properties* because as soon
as I click on Control Panel/Camera Scanner a window opens where I can
download the pics manually. Nothing there to click on that says properties.
No window asking me what I want to do, and no MS wizard. If I insert the
*flash stick* that window comes up - but then no MS wizard!!! IOWs, to get
the window to come up asking about the MS wizard I must use the flash-stick.
If I use the cable no window comes up at all - a WExp-like window opens
where I can manually download the pics and delete them from the camera. If
I click on *properties* with the camera NOT connected and turned on, it says
that the properties are not available. So how you get to see properties
with this camera is a mystery to me!
FS~
> be
> with
> MS
>> >> right
>> > from
>> > does
>> > it list?
> Camera.
>> FS~
Reply to Anonymous
- 0 +
This was posted as a possible fix, in another ng
http://www.microsoft.com/downloads [...] laylang=en
'Autoplay Repair Wizard' (http://tinyurl.com/5s4x7)
news:umgAh%23wmFHA.2904@TK2MSFTNGP14.phx.gbl...
> > card
> > reader.
> > installed correctly
just
to
> > a
> > usb port?
> > wizard -
scanner
the
correctly,
> > or
> In the resulting
> > window 'test'
> > What does it say?
soon
properties.
get
flash-stick.
If
says
> FS~
could
> > be
> > with
reader,
> > MS
> >> >> right
> >> > from
what
> >> > does
> >> > it list?
> > Camera.
> >> FS~
Reply to dl
news:O2lS6D3mFHA.3988@TK2MSFTNGP10.phx.gbl...
Why is it saying service pacl 1 when I have SP2 installed?
This is what happened:
AutoFix [V5.2.3790.67]
Time [2005-08-09 00:04:47]
Microsoft Windows Version [5.1 (Service Pack 1) <2600>]
Test [The Shell Hardware Detection service is running.] - Instance [N/A]:
Result [AutoStart Setting]: OK
Result [The Shell Hardware Detection service is running.]: OK
Test [Policies] - Instance [H:\, Drive Type: 0]:
Result [HKCU\...\Policies!NoDrives]: OK {Absent}
Result [HKCU\...\Policies!NoDriveAutorun]: OK {Absent}
Result [HKCU\...\Policies!NoDriveTypeAutorun]: OK {Present}
Result [HKLM\...\Policies!NoDrives]: OK {Absent}
Result [HKLM\...\Policies!NoDriveAutorun]: OK {Absent}
Result [HKLM\...\Policies!NoDriveTypeAutorun]: OK {Absent}
Result [Driver level policies]: OK {
HKLM\...\Services\!Autorun (Absent) <Allows>
HKLM\...\Services\\Parameters!Autorun (Absent) <Allows>
HKLM\System\CCS\Enum\...!AlwaysEnable (Absent) <Not set>
HKLM\System\CCS\Enum\...!AlwaysDisable (Absent) <Not set> }
Test [Drive Notification] - Instance [H:\, Drive Type: 0]:
Result [Legacy Notification]: Problems
Result [AutoPlay V2 Notification]: Problems {
Service (Silent)
Shell (Deaf) }
>> Repair << [Legacy AutoPlay Event]
Step: No steps to take.
Result: This AutoPlay setting cannot be fixed. Either the device is
malfunctioning, or the wizard cannot determine the problem.
>> Repair << [Autoplay V2 Event]
>> Required action: The wizard found problems but cannot fix them -> None
Before this I downloaded and installed the fix for C:\ = now the window
asking what I want to do doesn't come up.
FS~
>> > card
>> > reader.
>> > been
>> > installed correctly
> just
> to
>> > a
>> > usb port?
>> > window/app
>> > wizard -
> scanner
> the
> correctly,
>> > or
>> In the resulting
>> > window 'test'
>> > What does it say?
> soon
> properties.
> get
> flash-stick.
> If
> says
>> FS~
> could
>> > be
>> > with
> reader,
>> > MS
>> >> >> right
>> >> > from
> what
>> >> > does
>> >> > it list?
>> > Camera.
>> >> FS~
Reply to Anonymous
- 0 +
It appears to be saying drive H, I assume this is your card reader isnt
working/has an unidentifiable fault.
As I said before, I have seen reports of problems with the card reader
supplied on your sys.
Personnally I simply use usb from my camera, and use rechargable batteries
for that. But maybe I dont use it as much as you?
Considered buying an external usb reader, or do you have one you could
borrow, to test on your sys?
I dont know about your side of the pond, but here a retailer would refund me
if it did'nt work
"Before this I downloaded and installed the fix for C:\ ="
I have no idea what your refering to - sorry
news:eXBBPCKnFHA.2180@TK2MSFTNGP15.phx.gbl...
> Service (Silent)
> Shell (Deaf) }
> FS~
supplied
> >> > card
> >> > reader.
> >> > been
> >> > installed correctly
> > just
the
connect
> > to
> >> > a
> >> > usb port?
> >> > window/app
> >> > wizard -
to
> > scanner
up
name
> > the
> > correctly,
> >> > or
> >> In the resulting
> >> > window 'test'
> >> > What does it say?
> > soon
> > properties.
the
to
> > get
> > flash-stick.
> > If
> > says
properties
> >> FS~
> > could
> >> > be
readers"
> >> > with
> > reader,
> >> > MS
> >> >> >> right
> >> >> > from
> > what
> >> >> > does
> >> >> > it list?
> >> > Camera.
> >> >> FS~
Reply to dl
news:OLsU8xMnFHA.3316@tk2msftngp13.phx.gbl...
> me
> if it did'nt work
## H drive is the flash-card reader. I guess I'll just have to download
them manually from now on. What a king size pain in the (_|_) that is.
:-( The flash drive does work because I can go to WE and click on H
drive - and unload the card that way. So it does work and does see the jpg
files on the flash card.
## There was a "fix" at that website. I hoped it may help - it didn't.
Thanks for all your help. You and Sharon have the patience of saints.
FS~
>> Service (Silent)
>> Shell (Deaf) }
>> FS~
> supplied
>> >> > card
>> >> > reader.
>> >> > been
>> >> > installed correctly
>> >> the
>> > just
> the
> connect
>> > to
>> >> > a
>> >> > usb port?
>> >> like
>> >> > window/app
>> >> > wizard -
> to
>> > scanner
> up
> name
>> > the
>> > correctly,
>> >> > or
>> >> In the resulting
>> >> > window 'test'
>> >> > What does it say?
>> >> as
>> > soon
>> > properties.
> the
> to
>> > get
>> > flash-stick.
>> >> opens
>> >> camera.
>> > If
>> >> it
>> > says
> properties
>> >> FS~
>> > could
>> >> > be
> readers"
>> >> > with
>> > reader,
>> >> > MS
>> >> >> >> is
>> >> >> >> right
>> >> >> > from
>> >> >> > click,
>> > what
>> >> >> > does
>> >> >> > it list?
>> >> > Camera.
>> >> >> FS~
Reply to Anonymous
There are 1219 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
