Calculating total Power used from PSU.
Last response: in Components
Hi guys
So I've been installing new hardware over the past couple of months into a new rig, but im begining to think that my PSU is not powerful enough. Is there a way to calculate the total power being used by my components?
Spec:
PSU: OCZ Stealth X Stream 600w
CPU: Intel Core 2 Quad Q6600@ 2.4ghz
RAM: 2x2gb Kingston Hyper X 1066mhz PC2 8500.
GPU: nVidea Geforce GTS 250
HDD: 2x 500gb Seagate Barracuda 7200rpm
MOBO: Asus P5QLD PRO
O/S: W7 Ultimate x 64
Also taking power: heatsink fan, side fan, front fan, themometer and optical drive.
I am thinking of adding a further 2gb of the same RAM and another 1tb seagate baracuda 7200 hdd. Also adding a rear Fan. Will my power suply be able to handle this?
Is there a way of calculating the total power being used that anyone could reccommend?
Many thanks
Power supply Master
serth said:
Hi guys
Spec:
Many thanks
you won't break 300w on that set up.
CPU
Intel Core i7 965 Extreme (3.2 GHz, 8 MB L3 Cache, 133 MHz Bclk), power-saving settings disabled
Motherboard
Asus Rampage II Extreme (X58/ICH10)
Memory
Corsair Dominator DDR3-1600 8-8-8-24
Hard Drive
Seagate Barracuda 7200.10 250 GB 7,200 RPM
CPU Cooler
Thermalright Ultra 120 Extreme
CPU
Motherboard
Memory
Hard Drive
CPU Cooler
http://media.bestofmicro.com/9/Z/181799/original/image028.png
Hi! did you produce that graph using software? where can i find it?
Ask the community
