Front panel inputs are greyed out in my realtek hd audio mananger
Last response: in Components
December 11, 2010 10:01:32 PM
Im having trouble getting an output from my front panel ive tried the connector settings, where you un-click the disable front panel but for some reason this option is not even shown.
December 12, 2010 8:20:34 AM
mosox said:
Did you connect the front panel audio connector to the motherboard? Maybe this helps:
http://www.tomshardware.co.uk/forum/230110-10-realtek-f...
I had the computer built and upgraded for me is there anyway to check without going through the trouble of opening the computer up? I should also mention it worked before i upgraded and stopped right afterwards
m
l
