Graphic Card issue (maybe?) [+new build]
I'm having some problems with my new build.
Build:
i5 750
Asus P7P55D PRO
2x 2GB G.Skill ECO 1600Mhz CL7
EVGA GTX 460 768MB
Corsair TX650
First time I installed everything, the GPU Led from the motherbord turned red and didn't go off.
Then I reconnected the GPU and the monitor's cable a few times and fixed this issue. The computer was working fine for about a week.
I usually keep it ON during the night. When I woke up this morning, there was a BSOD ("Blue Screen Of Death").
But again, the GPU Led keep turning red :/ (I've tryed to reconnect again and again, and nothing happens)
GTX 460 issue?
Motherboard issue?
cables not connected properly?
Any ideas?
tks!
1 answer Last reply
More about graphic card issue maybe build
  1. If possible, install another GPU known to work fine (maybe borrow a friends) and see what happens, if that works fine then it may point to a GPU issue.
    MB issues are hard to tease out, best to test for everything else first.
    Also, what kind of BSOD are you getting?
Graphics Cards Build Graphics
